99 Expedition Windshield or Cowl Leak
Old Mar 15, 2010 | 09:04 AM
hgufrin's Avatar
hgufrin
HI everyone,
Had my windshield replaced Jan '10 because water was getting onto my GEM and fuse panel...
Had a downpour of rain for the first time this weekend... Expedition still leaks. Fuse panel was wet again...???
Can this Expedition be leaking from somewhere else? It is a rust free truck, only 128K on it, no accidents, perfectly clean vehicle...
Are cowls on this vehicle a problem??? Some sort of body seam???
The water is definitely coming from way up under the dash.
Thanks
Old Mar 15, 2010 | 09:46 AM
alloro's Avatar
alloro
Take it back to the place that replaced the windshield. It might be a problem with their installation and be covered under a warranty.
Old Mar 15, 2010 | 11:20 AM
hgufrin's Avatar
hgufrin
They (the autoglass people) are doing a pressure test on it right now. Provided that they did install it correctly...
Have any ideas where else it may be coming from?
Old Mar 15, 2010 | 03:01 PM
alloro's Avatar
alloro
Not yet, I'm hanging in there for a problem with the windshield installation.
Old Mar 15, 2010 | 05:46 PM
hgufrin's Avatar
hgufrin
AutoGlass center has the cowl cover off right now. He ran water down the front of the windshield for 30 minutes. Then ran water directly into the cowl... He simply can not get the problem to duplicate.
I was there watching and NO water is getting under dash now... Of course it has not been raining here for 24 hours straight so i cant prove it to him...
We are stumped.
If anyone has had a leaky cowl or body seam on a 99 Exp please let me know... I dont know what the problem is.
Thanks,
Hank
Old Mar 15, 2010 | 06:34 PM
alloro's Avatar
alloro
Try this...turn the heater blower to high (not MAX A/C) and close all windows and doors. This will mildly pressurize the cabin. Then either use a spray bottle or a sponge to apply a soapy water solution around the windshield. If it's leaking you will see air bubbles.
Do you have a moonroof?
Old Mar 16, 2010 | 07:19 AM
hgufrin's Avatar
hgufrin
Thanks for the reply. That is what is puzzling... the AutoGlass center pressurized the cabin, sprayed foam over the entire windshield and cowl area and NO bubbles.
Dont know where to go with this. Cant trade it in... Vehicle is in too good of shape... Urrggh.
Old Mar 16, 2010 | 10:01 AM
alloro's Avatar
alloro
Old Mar 16, 2010 | 10:08 AM
hgufrin's Avatar
hgufrin
Sorry, I neglected to answer. No, I do not have a moonroof....
And it only gets wet under the dash on the driver side kick panel wall... nowhere else....
The winshield doesn't show leaks from the top or on the pillar...?
Maybe i can use a flourescent powder or something that reacts to water and can show me a little better where it is originating from???
Old Mar 16, 2010 | 10:24 AM
alloro's Avatar
alloro
Hmm, maybe the front cowl drain is clogged. That's the area at the bottom of the windshield with the slotted air intake openings. I've seen the drains in those clog up and then they fill up and spill over everywhere.
TexasGuy001
24
Aug 29, 2022 10:49 AM
flyboys101
16
May 5, 2021 05:11 PM
rizob01
13
Oct 30, 2017 09:42 PM
Frank250Tank
Jul 12, 2016 10:14 AM
pidaster
Escape & Escape Hybrid
Aug 10, 2011 09:52 PM
