PUZZLING ISSUE WITH NITE BRONCO
![Exclamation](images/icons/icon4.gif)
I recently bought a 92 Nite Bronco, and was forewarned that it had some sort of electrical problem and wouldn't start. I got it home, and started tinkering with it, and I'm utterly baffled. With a fresh battery out of my running 96 EB, turn the key, and NOTHING. Power to the lights, radio, all the accessories, but nothing. I crossed out the solenoid, the motor will spin SLOWLY. The fuel pump does not come on, I checked the fuel rail, no fuel or pressure. I changed the computer, the starter switch under the steering column, and every other electronic device I could think of, out of my running 96, with the same result. The only think it does when you try to start it is the relays under the hood click, and I changed all of those out as well. Any help would be greatly appreciated. The guy I got it from said it ran when he got it (he inherited it after a friend died) but the tranny was slipping. He changed the tranny fluid and filter which fell out upon removing the pan (the possible cause for it slipping) and never got it cranked again. I know it's got to be something simple, but hell if I know, I'm counting on ya'll to show me the light.
Sometimes fuel pumps die or get stuck when they aren't put to work in a long time. First of all, get under the truck and hit the gas tank (a mace would work ok, try not to deform the tank, but give it some firm shakes) and try to start the truck. If that doesn´t work, swap the fuel pump relay (for a quick try, you can switch the relay with any other similar one). With the info you gave us, i think it's the fuel pump wich is causing the trouble (it will probably need replacing, just be warned).
The MLPS can cause starting issues if the shift linkage is misaligned or loose and/or the switch/sensor itself is damaged or loose. Its something you might look into in this case.
Are you getting full battery voltage at the starter? You might check the cables and connections. Do an actual resistance check on the positive cables running to the solenoid and the starter with both ends of the cables disconnected. You can get a +12VDC reading but only be getting a few amps through a bad cable which would cause the slow starter motor and lack of ignition. The starter pulls a significant amount of power down those cables and too much resistance (usually caused by corrosion or poor connections) will keep it from starting as well.
I have personally experienced this situation and had the cause be positive battery and starter cables corroded from the inside. The insulation and ends of the wire looked fine but when I took a meter to them I was getting better than 12 ohms resistance! Sure, the meter still showed battery voltage at the other end but there was no amperage. Like trying to put out a warehouse fire with a garden hose.
Ok, I see what ya'll are saying, but again, NO fuel pressure either, pump doesn't come on. The starter ONLY spins if I turn the key on and cross the solenoid, and there is no fire from the coil, And it stopped running when the previous owner changed the tranny filter, I'm about to go put my 96 EB in gear and try and start it, and see if I get the same thing, the only thing that happens on the bad truck is that the odometer goes off.
Ok, so it wasn't the battery cables, (although the ground cable was rather corroded) anyone else have any suggestions? Like I said before, no fire to the coil, replaced all electrical components I can think of, when cranking it, it just spins slowly, even with a hot battery. I'm still thinking MLPS.
