axle
I have been told that the .05 difference would not be noticable but I still don't have one anyway.
I have checked several salvage yards and all tell me they don't have one. I think I need to start asking for a truck axle instead of Bronco.
The 9" doesn't come in 3.55 and a 3.50 is worth its weight in gold around here.
Received 1,032 Likes
on
The 97 8.8 was told to me that the spring perches will not work due to a change in frame widths. It is what I was told, so I have no way to verify. Any axle from an 78 to 96 bronco/F150, and possibly as early as 72, should bolt right on your Bronco... Though the 90+ may have a flange rather than a yoke on the input shaft.
As for the VSS, he has an 86 so he may or may not need the VSS depending if he has fuel injection or not. But wouldnt his VSS be on the transfercase/ speedo cable because 86 didnt have RABS.
Agreed, 86 didn't have a VSS. And even if he does have an EFI engine, the VSS was only utilized by the E4OD/speedometer and the cruise control computer. Neither of which were even present in an 86. Cruise was still vacuum and magnets and with the transmissions available in 86, the speedometer was still cable driven. The E4OD (not available until very late 89 with most being 90) required the use of the VSS for speedometer and shift point designation.
The wheels from an '86 will not fit a '97. They use a metric bolt pattern. They are close and you can probably bang them on, but this is a very unwise idea.
If you have an '86 Bronco, you need an axle from a 1989 or older F-series or Bronco. Sometime in 1990 is when Ford when from the yoke input to the flange input.
