Help with horn setup 46 ford pickup
Old Mar 9, 2010 | 09:54 AM
46fordphil's Avatar
46fordphil
Question Help with horn setup 46 ford pickup
I am getting ready install the horn wiring, etc. on my 46 Ford 1/2 ton pickup and am not sure what parts I need to get the horn setup. I am going to have to purchase all new parts. I can get most from Macs, but surprisingly they are not aware of the full set of parts needed. My question deals with how the setup works, and thus what parts are needed to complete it. Is there a schematic out there showing the parts and how they go together? I presume that I will need a relay to operate the horn also. Any ideas and help would be appreciated. phil w.
Old Mar 9, 2010 | 10:33 PM
46fordtruck's Avatar
46fordtruck
Phil, check out this wiring diagram, it will show you how to set it up. It is the same diagram found in the original shop manual. http://www.vanpeltsales.com/FH_web/F...46-47truck.jpg
The set up is quite simple. From the horn there is a wire that runs up through the steering shaft to the horn button. You can get the new switch and all from Mac's. The other wire from the horn runs to the circuit breaker under the dash. No additional relays are needed.
Old Mar 11, 2010 | 06:27 PM
46fordphil's Avatar
46fordphil
Thanks for the information. Appreciate your help. phil.
OldHarley
Dec 16, 2019 02:25 PM
KDeYoe
Nov 12, 2016 02:25 AM
dondolittle2
Apr 19, 2016 05:24 PM
Superred2
Dec 25, 2010 11:06 PM
Flea
16
Apr 2, 2008 09:12 PM
