Cruise Control Horn pad replacement
Old Dec 10, 2007 | 02:19 AM
Flea's Avatar
Flea
So, I was told about the horn pad replacement and plug and play capability by just getting a new horn pad w/ cruise on it.
I pulled off my horn pad tonight and all I saw were two wires going to the horn and no other electrical cord or cable.
Am I missing something or do I need to dig deeper?
If not how far down do I need to swap out with a truck that does have the cruise on it to get the wiring harness for cruise?
Thanks,
fletch
Old Dec 10, 2007 | 04:47 AM
Cuda_jim's Avatar
Cuda_jim
I ran across this on FTE.
https://www.ford-trucks.com/forums/5...ghlight=cruise
I can't tell you from experience but spikebee has first hand knowlege. Drop him a PM, I'm sure he'll help you.
Old Dec 10, 2007 | 07:36 AM
tjbeggs's Avatar
tjbeggs
Yes from what I have heard just remove the horn pad and install a CC horn pad. The CC pad only has 3 wires I beleive and its just one plug.
BTW Jim you need 1 more post for 3K!! hit it!
Old Dec 10, 2007 | 12:30 PM
Cuda_jim's Avatar
Cuda_jim
Yahooo! 3K posts, Does this mean my truck has extra HP now? lol
Maybe a cracker jack prize, Must be referring to Al Gore huh?
Old Dec 10, 2007 | 02:46 PM
tjbeggs's Avatar
tjbeggs
3k is near 50hp!!!
Right on!!
Maybe I will be asked to remove my political line again but oh well!!
Old Dec 10, 2007 | 03:45 PM
Flea's Avatar
Flea
I guess I am confused slightly.
All that is under my pad is two wires. Do I only need the cc horn pad or do I need a new steering wheel?
Thanks a bunch.
Old Dec 10, 2007 | 03:50 PM
tjbeggs's Avatar
tjbeggs
No you just need the CC horn pad. I will try to take a pic of mine this evening for you.
Old Dec 10, 2007 | 03:54 PM
Flea's Avatar
Flea
Thanks a bunch Tim.
I will get the horn pad.
Old Dec 10, 2007 | 04:42 PM
tjbeggs's Avatar
tjbeggs
here's pics
http://community.webshots.com/album/559337499LWFwVN
Old Dec 10, 2007 | 05:13 PM
Flea's Avatar
Flea
So the new cc pad will have the three wires.
I see the two wires coming out of your steering wheel but I only have two.
Old Dec 10, 2007 | 05:55 PM
tjbeggs's Avatar
tjbeggs
yes should have 3 wires. when you unplug your wires are there 3 pins in the steering wheel end of the connector?
Old Dec 10, 2007 | 06:36 PM
Flea's Avatar
Flea
Okay I found the three pins but I don't have the three wires. Does the new horn pad come with the three wires?
This is where I got confused.
So, it looks as if everything is there for the cruise except the three wires and the horn pad.
Old Dec 10, 2007 | 06:58 PM
tjbeggs's Avatar
tjbeggs
Correct. everything you need except the horn pad and wiring
Old Apr 2, 2008 | 08:21 PM
maverick1701's Avatar
maverick1701
so just to make sure I understand this correctly... if we do NOT have CC we should only have 2 wires correct?
Old Apr 2, 2008 | 08:26 PM
tjbeggs's Avatar
tjbeggs
yep if you have CC you will have 3 wires if don't have CC then 2 wires.
