Sponsored by: Real Truck
6 inch lift
Old Jan 31, 2010 | 09:19 AM
bittersweetfox's Avatar
bittersweetfox
6 inch lift
anyone have an sd with a 6 inch lift, and do u have any driveline vibration, or did u do some mods to prevent it?? thanks
Old Jan 31, 2010 | 10:18 AM
2000silverbullet's Avatar
2000silverbullet
If you have a long bed, you can add in a spacer in the carrier bearing which will lessen the driveline angle. I have one I believe I bought from Rubicon Express.
Old Jan 31, 2010 | 10:19 AM
Pocket's Avatar
Pocket
Drop the carrier bearing on a two piece driveshaft. Most high quality kits come with the shims in the kit.
Old Jan 31, 2010 | 11:11 AM
jlmotox's Avatar
jlmotox
x2
had to drop my carrier bearing 2"...before that it was vibrating pretty good.
Old Jan 31, 2010 | 11:34 AM
bittersweetfox
thanks i have a short bed ext cab, v10 6 speed. so far im thinkin about putting together my own kit, most kits lift the rear 2 inches less and i dont want my truck to sit a lil low in the back, or the kits r very expensive. so far national tire and wheel has the best prices, what have u guys found out??
Old Jan 31, 2010 | 04:56 PM
Furian's Avatar
Furian
You Keep What You Kill
I reviewed the 6" lift kits at National Tire & Wheel. They carry the popular brands like Skyjacker, Pro Comp, Super Lift, etc. What is your budget for this lift kit? Do you plan to run 35" or 37" tall tires? What gears do you currently have in your axles? How long do you plan to keep the truck?
Old Jan 31, 2010 | 05:15 PM
bittersweetfox
probably 35s, i have 373s but intend on switching to 410s
Old Jan 31, 2010 | 05:35 PM
SHAWN056.0's Avatar
SHAWN056.0
I've got an 05 crew cab with 6 inch lift running 35s. I shimmed the carrier bearing and had vibration, actually worst then it was stock. Took the truck to a driveline specialist and they told me to keep it stock form so I put it back and it drives like a dream. Go figure.
Running 35s your pretty close to stock so changing the gears is not necessary unless you just want more low end power. Anything above 35s and I would say yes to changing gears. Anywho just my two cents. Good luck
thanks
Shawn
Old Jan 31, 2010 | 08:53 PM
Furian's Avatar
Furian
Installing 4.10 gears with 35" tires will get you very close to the same RPM's as you currently have with 3.73 gears and 31.5" tires. You can use the RPM Calculator below to determine which gears are best for your application. Your 6-speed transmission has a "Transmission High Gear Ratio" of .72.
RPM Calculator
Do you plan to keep the stock 16X7 wheels or use aftermarket wheels?
Old Feb 1, 2010 | 08:23 PM
bittersweetfox
prolly gonna go with 16x10s
Old Feb 1, 2010 | 09:38 PM
Furian's Avatar
Furian
The reason that I asked about the wheels is that if you purchase new wheels with the appropriate back spacing (4.5"), you can get away with a 4" lift kit and 35" tires.
Have you considered that option?
Old Feb 2, 2010 | 01:05 PM
Bruce F250's Avatar
Bruce F250
I Just ordered 35s on 20 x 10s w/ 4.79" BS. can I get away w/ 4" or do I need 6"?
Old Feb 2, 2010 | 02:26 PM
Furian's Avatar
Furian
IMO, a 4" lift kit looks better than a 6" lift kit with 35" tires. Now, if you do serious off-roading, you may want the 6" lift kit for better wheel articulation.
Here is a 2004 F250 with a 4.5" (should be 4") Icon lift kit and 35" tires on 20" wheels.
Here is a 2004 F250 with a 6" Icon lift kit and 35" tires on 20" wheels.
There is not a noticable difference in these pics. You can go to the link (gallery) below and see the various configurations for more examples.
http://www.trucktoyzperformance.com/...earch-blue.php
BTW, what wheels did you order? That's an unusual BS for a 10" wide wheel...
Old Feb 2, 2010 | 02:30 PM
Bruce F250's Avatar
Bruce F250
Thanks for the comparison.
Wheels are Moto Metal 951.
Old Feb 2, 2010 | 02:47 PM
Furian's Avatar
Furian
A very popular wheel... for good reasons!
