6 inch lift
so heres what i bought... 4 inch pro comp front springs and u bolts, skyjacker sway bar end links, pro comp pitman drop arm, superlift adj track bar, superlift 3 inch rear block kit, pro comp es 9000 shocks, and pro comp steering stabilizer, and 16x9 moto 951s and it only cost $1300!! now do i wanna run 305 70s or 315 75s thinkin about fierce attitude mts...?
set up your gallery!!
Hey all...quick question, i have a 04 250 crew cab that im runnin 37x13.50 with a pro comp 6.5 lift. I keep going back and forth on what gears im gonna go to. 4.10s or 4.56? The truck is my daily driver so Im trying to get the power back that ive lost as well as gas mileage. so what do yall think?
6-Speed Manual - .72
4R100 Automatic - .71
Torqshift Automatic - .71
RPM Calculator
this is what i think seems to work out fairly well, for every inch in diameter u add go .10 lower in gear ratio. ex if u have 31 inch tires stock with 3.73 ratio and u go to 35 inch tires to get rpms close u would go with say 4.10 gears. if anyone doesnt think this is fairly accurate let me know
bbcfast1
13
12-30-2013 07:52 AM
powerstroke 6.0
02-02-2008 12:37 AM
