Sponsored by: Real Truck
Is truck actually shifting into 4x4?
Old Jan 31, 2010 | 08:52 AM
afinepoint's Avatar
afinepoint
I hear the "clunk" and the light on the dashboard is lit but I question whether I am in 4 wheel drive.
Lately we have had two heavy snows here in Virginia. On plowed roads or in a few inches of snow the truck handles fine in 4x4 but when I stop and try to start again in 6+ inches of snow/slush or when moving if the snow is high enough that the wheels are plowing then the rear wheels will spin and I have to rock the truck or back up and try again. The front wheels never spin. It is just like driving a rear wheel vehicle. I have heard that snow can pack between the rear wheels and lift them off the ground. I can't tell if this is happening.
The tires are Khumo Ventures and have good tread. Is this just a dually issue? I don't believe so because I have spoken with someone with the identical truck and he plowed with it.
It's frustrating struggling to get out the neighborhood or getting stuck 20' out/from the driveway and embarrassing watching the SUVs zip by.
This morning I made it 42 miles home only to spin rear tires 30 feet from my driveway. The street has a slight uphill grade was unplowed. I had to turn around and park on the side of road.
Reg
Old Jan 31, 2010 | 10:18 AM
Pocket's Avatar
Pocket
Almost sounds like you have one hub locked, and another unlocked.
Old Jan 31, 2010 | 10:38 AM
Furian's Avatar
Furian
You Keep What You Kill
Reg
It sounds like someone has buried "kryptonite" under your driveway... Just kidding!
Old Jan 31, 2010 | 12:59 PM
wideglidewoody00's Avatar
wideglidewoody00
Sounds like the transfer case is engaging but the hubs are not locking in. If you have the ESOF system then the hubs will say locked and auto. Turn the hub to locked and try it and if it works then you have a problem in the auto system. Do a search on here, plenty of questions answered about 4x4 engaging problems. Hope this helps.
Old Jan 31, 2010 | 01:50 PM
hanklin's Avatar
hanklin
sounds like a vacuum leak to me,Is it esof or a floor shifter?
Old Jan 31, 2010 | 03:08 PM
afinepoint's Avatar
afinepoint
Electronic. Switch on dash.
Reg
Old Jan 31, 2010 | 03:24 PM
hanklin's Avatar
hanklin
Has anybody actually stood outside to see if front are turning? You said they never spin but is that confirmed> I have a floor shifter so sorry I cant help you but if you. search this forum and type in ESOF and there is alot of info,good luck.
Old Jan 31, 2010 | 03:33 PM
afinepoint's Avatar
afinepoint
Thanks for the input. Wide - I did look up 4x4 engaging issues here. Good suggestion. I thougth it would be another forum.
Hank: I mentioned to the wife she would need to watch the front wheels to check for spin.
Also I had forgotten about manually locking the hubs and some wheel spin is necessary for engagement. Another great reminder.
To all thanks again. I'm working 12 hour night shift these past days and the brain is not properly "engaging".
Reg
Old Jan 31, 2010 | 09:42 PM
afinepoint's Avatar
afinepoint
With the truck in "4x4" (light lit) I turned the front left axle by hand. So I know that side was not engaged. Couldn't get to the other side as snow was up to the door.
Looking for a vacuum leak now or solenoid issue.
Thanks again.
Reg
Old Jan 31, 2010 | 10:00 PM
redford's Avatar
redford
FTE Leadership Emeritus
Just manually lock the hubs until you can get to them. It won't hurt anything to have the hubs manually engaged until you can troubleshoot the issue. Just flip the switch and select 4H when you need it.
Old Feb 4, 2010 | 08:03 PM
afinepoint's Avatar
afinepoint
The plan is to do just that redford. Crud was causing the right hub to bind. Both were cleaned. I will hunt about for the reason the hubs are not engaging later. No plan to spend $98/hr in shop troubleshooting + cost to repair.
For now I have to deal with the 3 to 24" of snow heading this way tomorrow and Saturday.
Reg
