Major fuel problem ... NEED expert Advice * updated *
Old Jan 12, 2010 | 10:42 AM
Big-old-460's Avatar
Big-old-460
Cool Major fuel problem ... NEED expert Advice * updated *
this jsut happen ...>!!!
1) my dash switch isnt working from front to rear tank ... front works fine when i switch to the rear eather it dies out Quick like the truck isnt getting enough gas or it just wont work!!
2) WTF!!!! i filled up my front tank drove over 10 miles and it died ?!
check the tank and found out all my GAS from my front tank was Pushed into my rear tank... ?!
3) when i turn the key to power on everything not to start the truck..
I hear Humming coming from my tanks
I NEED SOMEONES EXPERT ADVICE ON FUEL SYSTEMS AND WHATS HAPPENING...
Thank you f.t.e members for input ...
*updated * I figure out whats going on,, BUT everythread or manual on fuel systems is not explaing WHY the fuel from my front tank when driven is being completely empted into my rear tank ?!?! And fast.. a Full 17 gal front tank will empty in to the rear tank in a matter or 10 miles or so ..
jayson
1994 / f-350 / 460 efi /4x4 extra cab full bed../ 12 inch lift 40 inch swampers
Old Jan 12, 2010 | 11:11 AM
quaintance's Avatar
quaintance
I found this in the sticky post at the top. Hope it helps.
Q
https://www.ford-trucks.com/forums/2...re-issues.html
Old Jan 12, 2010 | 11:37 AM
BigBlueOx's Avatar
BigBlueOx
This is a common problem. You should be able to find something in a search.
Old Jan 12, 2010 | 12:14 PM
Big-old-460
Q
its helps but i am not sure what to replace, my fuel pumps and filters , and the switch ? seems like a whole new system cant i just make it ONE BIG TANK ah ha
Old Jan 12, 2010 | 01:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Search for crossflow issues and you will come up with many posts.
Not too sure about a '94 but I think the issue would be the in-tank check valve.
The recall I find (93S68) affects ->1993 FPR's but there are still issues with later trucks that can be dealt with by using an external check valve (1L3Z-9J274-AA) from what I understand.
Old Jan 12, 2010 | 02:02 PM
Big-old-460
thanks also reading chilton manual atm .. thxs guys
Phobia16V
36
Jan 18, 2021 04:01 PM
Ex-ChevyOwner
Oct 7, 2015 09:14 PM
mike L
39
Nov 23, 2014 09:33 AM
Big350
Nov 11, 2013 11:31 AM
lud04X
Dec 3, 2011 09:58 PM
