Sponsored by: Auxito
Helping to prevent hydraulic clutch wear/failure.
Old Jan 10, 2010 | 06:55 PM
EZFEED's Avatar
EZFEED
Hey guys, are any of you adding anything to the fluid of your hydraulic clutch reservoir to prevent wear?
I'm talking about these years system with the plastic master cylinder and the piston with throwout bearing built in.
This is the only other part that I did change on my truck that I forgot to mention. I have never had to change the slave but I did change the master once due to internal leakage.
I think it's a pretty slick setup actually, I may even use it for some hotrod projects or to use with my 351W swap on my 67 convertible mustang. Pretty compact and will fit in tight areas and pretty easy to service too (except for the slave of course).
Since the master change I added some lucas power steering treatment (about 4 tablespoons) to the Dot 3 in the reservoir. Been working slick as can be since. Any of you tried anything better or know of something more compatible with brake fluid. I'm fixing to purge the clutch system and brake system tomorrow and was thinking of adding something more soluble.
Old Jan 22, 2010 | 09:51 AM
monckywrench's Avatar
monckywrench
Hydraulics where hydraulics aren't required is ensuring hydraulic failure, ensuring system complexity, and ensuring high parts count. Clutches are best actuated by cable or mechanical linkage, but hydraulics are slightly smoother and most buyers, being mechanically illiterate, prefer smooth and don't connect it with repair cost.
I wouldn't add anything to hydraulic fluid without testing it, meaning OUTSIDE the target system. Mixing petrolem with brake fluid can't end well, and will probably result in goo. That you are worried about the DESIGN defects of the clutch system proves the design stinks, especially the slave cylinder that requires a trans pull to replace.
bluemtn95ford
1983 - 2012 Ranger & B-Series
Apr 5, 2015 06:37 PM
squirrel64
Feb 26, 2014 07:07 PM
BlueOvalRage
May 19, 2010 03:16 AM
MaxBurn
Jul 22, 2004 10:42 PM
Tony G
Jul 15, 2004 01:35 AM
