seat armrest removal
Old May 4, 2009 | 07:27 PM
yonu's Avatar
yonu
ok quick question how to you remove the armrest/storage of the 93 model driver seat?
Thanks,
yonu
Old May 4, 2009 | 08:33 PM
michigan66's Avatar
michigan66
Remove as much of the cover on the armrest as you can. On the right side of the foam, near the back of the armrest you will find a hole. You will need a long extension and a star socket (I'm not sure of the size). The bolt has right hand threads and is in tight. You may have to work at it to get it loose but be patient with it.
Good luck.
Old May 4, 2009 | 08:42 PM
yonu's Avatar
yonu
then I take it there is not a simple way to do it as I intend to reinstall?
as i am mainly after getting the liner out of it
Old May 5, 2009 | 07:56 AM
michigan66's Avatar
michigan66
The cover has a zipper along the side, so getting it removed enough to get to the bolt hole is not a problem. I've removed mine but did not reinstall. I would think reinstalling the arm rest should be fairly simple and straight forward. All you need to do is follow the removal steps in reverse.
Old May 5, 2009 | 09:38 AM
yonu's Avatar
yonu
ok no luck mine doesn't have a zipper on it
Old May 5, 2009 | 01:40 PM
michigan66's Avatar
michigan66
Sorry about that, mine did. Question: You mentioned "armrest/storage." Does that mean there is a storage compartment in the arm rest? Also, what kind of covering does the armrest have? Mine has a steel core with a block of foam molded around it and has a fabric cover that matches the seat upholstery. How does that compare to what you have.
As I think about it more, your '93 is one generation newer than my '91.
Hopefully someone else will come along and help you out.
Old May 5, 2009 | 06:58 PM
yonu's Avatar
yonu
the one on mine is a fabric covered storage compartment that doubles as an armrest/seatback for center seat
Old May 5, 2009 | 08:48 PM
michigan66's Avatar
michigan66
We are talking about a Ranger,aren't we?
Old May 5, 2009 | 09:50 PM
yonu's Avatar
yonu
yeap 93 reg cab xlt
Old May 6, 2009 | 04:59 PM
tom_foreman's Avatar
tom_foreman
I have the same. It is a center console that has one wide arm rest that lifts up for storage. I took a quick look at mine but I needed extra light to see how it comes off. As it is about to storm here I'll have to wait.
Old May 7, 2009 | 04:31 PM
nelstone74's Avatar
nelstone74
Im pretty sure you have the same one that I have in my ranger. You need to open the door and look on the inside there will be a little acsess panel in the middle pop it off and you will see the head of the bolt (that is what holds it on and is the pivot point. IIRC it is a torx drive (bigger one maybe T50)
Old May 7, 2009 | 08:55 PM
yonu's Avatar
yonu
thanks I had ran my hands all through the darn thing and never noticed the cap anychance you know what the trick is to getting the plastic insert out?
Old May 8, 2009 | 12:38 PM
nelstone74's Avatar
nelstone74
I used a pocket knife to get under the edge and pry it off,
Old May 10, 2009 | 10:05 PM
yonu's Avatar
yonu
well I got it apart turns out on mine under the felt carpet stuff is 4 screws
I thought I would post a couple of pics to show you folks what I am doing
these will be for my power windows and locks I have never liked door mounted switches
Old May 8, 2025 | 01:46 PM
darealgusmccrae's Avatar
darealgusmccrae
2nd Gear
87 ranger armrest removal tool
Anyone know what tool is needed to remove the armrest out of an 87 Ranger? Picture attached shows looking in from passenger side.
Fordtruck7891
Aug 7, 2017 06:26 PM
yonu
North Carolina Chapter
Apr 10, 2015 09:00 AM
yonu
Oct 28, 2014 06:19 AM
jamwiest
15
Mar 15, 2010 06:44 PM
pachangalpina
Sep 30, 2005 05:45 PM
