1978 - 1996 Big Bronco
1988 bronco rotors
Old Apr 14, 2009 | 10:36 PM
993/4ton's Avatar
993/4ton
1988 bronco rotors
I have a 1988 bronco with manual hubs. Has anyone done the rotors on a truck like mine? From reading the manual it looks like you have to press the hubs out of the rotors at a machine shop. Any help?
Old Apr 14, 2009 | 11:05 PM
Nev. Bronco's Avatar
Nev. Bronco
You are talking about the hub rotor that has the standard assembly like a 79? I did a set in the past and a major pain!. You have to press all the lug bolts out and I tried to reuse them. Went together but a week later walked out all the holes and trashed both hub and rotor. Napa has them in one part. Also LMC and bronco graveyard. If you have to use your hub get new bolts. High speed die grinders have a buffing wheel brown in color. Clean all the surface of the hub where it mates to the rotor or it could make it out of square. Although most of the time I have had to take the new hub rotor to have it turned because it isnt true or square. Out a few thousanths makes a diff . Pressing the parts together, Well, good luck
Old Apr 15, 2009 | 11:54 AM
SpectreZ91's Avatar
SpectreZ91
spend the extra cash and get them with the hub attached to the rotor already.. Saves a lot of time and headache.
Old Apr 15, 2009 | 12:39 PM
Kemicalburns's Avatar
Kemicalburns
sounds like he has the top hat hub style is this correct?
Old Apr 15, 2009 | 04:45 PM
993/4ton's Avatar
993/4ton
So I got my driver side rotor off. Not too bad of an ordeal except getting that lockring off for the hubs. This is what I found holding the spindle to the knuckle. (spindle already removed in picture)
After a call to the dealer, I am informed that the studs and nuts I need are discontinued. After some searching, I found a place in Cincinnati that has a TON of discontinued Ford parts that they buy up from dealers once Ford discontinues the part. I ordered all six next day air.
The passenger side hub was being held together with a phillips head countersink screw instead of the spring, so that gave me an excuse to put a new set of Warn hubs on it.
Also discovered the lower ball joints have about 1/2 inch of play. I will be replacing them and all front end bushings/tierods/swaybar bushings tomorrow.
Here's to what tomorrow may bring!!
Old Apr 15, 2009 | 05:22 PM
Nev. Bronco
Since you are going that far, you'll need to change, probly the inside spindle bearings and seals and the larger seals and metal slingers. I'd also check the axle u-joints. How are the axle seals for the diff? If you have to change them, you have to pull the carrier. There from the inside of the diff. That is so fun too.
Old Apr 18, 2009 | 11:59 AM
Grogtronics's Avatar
Grogtronics
Replacing the rotors wasn't all that hard I did it with out using any press. I started the studs on by tapping litly with a hammer put a generous amount of anti sieze on them and tightened them up on the wheel with an impact gun checking the studs after they were all tight to make sure they where fully seated then proceeded to put everything together.
Old Apr 18, 2009 | 08:23 PM
American Thunder's Avatar
American Thunder
It's pretty straight forward, I've done a lot of them over the years. When you re-use the studs, make sure you line up the splines with the original spline-imprints on the hub, so they fit back together easily.
gabenheimer
Jul 5, 2016 08:57 AM
camper08
15
Jun 15, 2014 07:35 PM
Mallow
Nov 11, 2011 04:31 PM
james_kiehl
Jul 1, 2011 03:05 PM
free90xlt
Dec 16, 2007 02:03 PM
