1978 - 1996 Big Bronco
Front End Camber/bushings
Old Apr 10, 2009 | 01:46 PM
993/4ton's Avatar
993/4ton
What would cause the camber to go way out of whack after I back the truck up? If I back in to a spot, when I get out of the truck, the front wheels have a TERRIBLE camber (top pointing in). If I pull into a spot going forward, they are fine. I have looked under the truck and nothing LOOKS out of the ordinary for a 20 year old truck. I know I will have to change out some bushings, just need to know which ones. Thanks!
Old Apr 10, 2009 | 05:07 PM
Kemicalburns's Avatar
Kemicalburns
this is normal. all TTB ford broncos/f150 do this.
Old Apr 10, 2009 | 11:08 PM
McLeod's Avatar
McLeod
My '95 Bronco did this until I put in new axle pivot bushings and ball joints.
Now it doesn't.
Old Apr 13, 2009 | 12:57 AM
greystreak92's Avatar
greystreak92
E-series vans are prone to the same condition.
Yes, axle pivot bushings may help a bit with the appearance but it will still be there a little. There is only so much you are gonna do with that many moving parts under there.
Old Apr 13, 2009 | 11:48 AM
993/4ton's Avatar
993/4ton
I am gonna do the axle pivot bushings, and the radius arm bushings while I am at it. It is BAD. So bad that when I back into my parking sopt at work, guys come up and ask me what is wrong with it.
jaroh
Jun 6, 2013 10:11 PM
67-F100
20
Mar 27, 2013 05:43 AM
srsparky32
Aug 20, 2011 09:33 PM
Flat Black
Jun 21, 2010 10:20 PM
jarbeau
Jul 17, 2008 11:25 PM
