coil spring/camber/alignment
Old Jun 21, 2010 | 08:06 PM
Flat Black's Avatar
Flat Black
Hey all, Been lurking here for quite some time and now I have a question worth asking .
I've been following the Show 'em thread and need some input on coil spring/camber/alignment.
To start with I have a 1984 F150 Flareside, 2wd, 4.9, automatic. I plan to "streetrod" this thing in due time, but for the meantime I'm going to stick with the 4.9(it runs too good to get rid of).
So to the question- I took it to the alignment shop and had everything set to "spec" and it looks like it is set at too much camber(tops of the tires leaning out- don't know what it's called + or -). So is this "spec" for when the truck was new, before the springs settled(it has 150,000 on the ticker now) or is this much camber needed to get proper tire wear?
Not to mention it steers terrible. It's very touchy, but it seems to wander from one side to the other. I've already replaced the radius arm bushings and I beam bushings with new polyurethane. The only other thing I can think of is to replace the rag joint.
With this much camber, I was thinking of trying a set of Lightning springs as I wanted to lower the front a little anyway. If the springs lower it, it should take some of the camber out of it right?
Does anyone have any pics of our trucks with Lightning springs on it?.....Mike
Old Jun 21, 2010 | 10:20 PM
RVF150's Avatar
RVF150
Ive been wondering about my alignment also. I recently had new springs and shocks installed along with radial arm joints. After the alignment the wheels look tilted in at the bottom by atleast 2-3 degrees if not more. I didnt notice untill I got the truck home or I would of asked at the shop.
A few weeks later I think it looks a little better (I think the springs have settled some) but Im not sure how much I should expect them to. I need to have new tires installed soon anyways so I planed to ask about it when I returned, but in the meantime can anyone say if that sounds correct for a stock setup ?
KWIZ
May 11, 2014 08:38 AM
kermit5327
May 19, 2013 12:07 AM
friscofordguy
Feb 14, 2012 11:07 AM
srsparky32
Aug 20, 2011 09:33 PM
