rear wiper motor
Old Jan 8, 2009 | 06:49 PM
greenterror's Avatar
greenterror
Question rear wiper motor
is this a hard part to replace?
Old Jan 8, 2009 | 07:14 PM
madsonp's Avatar
madsonp
What I'd try if I were you before replacing the motor is......with the wiper switch on high, go to the back, grab the wiper and jiggle it up and down for a few seconds. Sometimes this will get it working again. If that doesn't get it working, check the relay under the hood to make sure it's working. With the wiper switch on you should hear the relay clicking under the hood. If you don't hear this then check your fuse, if the fuse is ok then it's probably your relay. If it does come down to replacing the motor, it isn't that difficult to do. Just remove the trim pannel on the rear hatch and you'll see it in there.
Old Jan 9, 2009 | 10:04 AM
alloro's Avatar
alloro
No, pull off the door panel and the wiper arm. The motor is held in by 3 bolts and one wire connector.
Old Jan 9, 2009 | 10:16 AM
MOOK929RR's Avatar
MOOK929RR
i definitely try turning it on, and jiggling it around a bit before u look into replacing it. Mine appears to be crapped out about 20 diff times over the past 5 years...i go back there and wiggle it around, and it starts working fine again. I dont know if it just gets stuck or what... i think the design they have where the wiper arm has to drop below the glass when turned off is a bad one, and causes the arm to get stuck down there...
Old Jan 9, 2009 | 02:28 PM
pitrow's Avatar
pitrow
What he said. It takes all of 20 minutes to replace.
Old Jan 9, 2009 | 03:33 PM
alloro's Avatar
alloro
If it didn't drop down how would you open the glass?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
