remote start on my 06 Navigator
Old Dec 30, 2008 | 11:24 AM
90F250351's Avatar
90F250351
i have an 06 navigator and would like to add a remote start. what is the easiest/most cost effecient way to do this? i dont really want to get into adding a full blown alarm system. i am fine with the keyless entry. someone i know had a show add a remote start to their same year navigator that uses the factory keyless enty transmitter. they just hit the lock buttom 3 times and the truck starts. anyone know anything about this?
Old Dec 30, 2008 | 08:11 PM
90F250351's Avatar
90F250351
anyone have any ideas???
Old Dec 30, 2008 | 11:24 PM
DROOPY209's Avatar
DROOPY209
Yes, you will need an immobilizer bypass module. Peripheral electronics makes one that I really like and you don't have to lose a key, but I am biased since I use Peripheral and Idatalink products. You only need one key to program it.
I know that Ultrastart and DEI both make add-on remote start units that use your keyless entry remote to activate the remote start sequence.
Are you doing this installation yourself or are you taking it to a professional shop?
Old Dec 31, 2008 | 07:55 AM
90F250351's Avatar
90F250351
i would do it myself if its not too complicated, but otherwise i will have it professionally done
Old Dec 31, 2008 | 09:25 AM
Z06PSI's Avatar
Z06PSI
Looking to do the same whenever I replace the head unit in the dash.
Old Dec 31, 2008 | 02:53 PM
DROOPY209's Avatar
DROOPY209
If you have a DMM, there's not much to it. The immobilizer bypass module will be hooked up to the add on remote start unit with one wire and the bypass module will also connect to a couple wires that come out of the ignition tumbler on your Navigator.
All you're gunna really need to hook up is 12v constant, ignition, starter, accessory, ground, brake wire, tach, door lock, and maybe a hod pin trigger if the unit comes with one.
The tach is easy to get on cylinder #8, on the coil or on the fuel injector wire.
You don't really have to hook up the accessory, but if you want your heater or A/C to be running when you get inside, you need to hook that wire up.
Old Jan 2, 2009 | 07:43 PM
kevinjjedwin's Avatar
kevinjjedwin
use a ford remote start system and there is only about five wires to connect and usually it warrantied by ford
Old Jan 3, 2009 | 07:36 AM
Z06PSI's Avatar
Z06PSI
Detail for Lincoln Navigator Remote Start Systems - FordGenuineAccessory.com
Is this right? It just looks like a plug and play module.
Old Jan 3, 2009 | 01:14 PM
widebody95's Avatar
widebody95
Remote Start - Tach wire
I am installing a remote start on my 98 Expedition. The instructions told me that the tach wire would measure anywhere from 0.5vac to 6vac. I measured and got 13vac. I called tech support @ directed electronics and after I was on hold for almost an hour, he told me to try and connect to a "non-common" fuel injector wire. Well, I measured and got more of a pulsating dc voltage than a true ac voltage, which I could see that the system could possibly think it to be an ac voltage. I just want to make sure before I make the connection that it won't fry the brains of my remote start. Any thoughts???
Old Jan 3, 2009 | 03:05 PM
alloro's Avatar
alloro
Responded to this in your new thread.
Old Jan 3, 2009 | 03:38 PM
kevinjjedwin
yes it is a plug in module and connect wires for the horn,park light,brakes,ground and optional doors lock wires ,the other wires need not to used.
Old Jan 3, 2009 | 05:26 PM
Z06PSI's Avatar
Z06PSI
For 28.95? That seems to be cheap.
Old Jan 7, 2009 | 10:51 AM
lbinh's Avatar
lbinh
Remember to program the door keypad to arm and disarm if you choose a remote start system with an alarm. Also, you have to have a module for the power running boards to deploy properly with remote start.
I have the six button ford/lincoln remote start system installed by the dealer for my 2005 Navi. It is really made by Audiovox. About $585 total. No extra key needed/used to bypass chip in key(PATS), just a ford bypass module needed. Works flawlessly except for the fact the power running boards and radio have a slight delay to deploy when using remote start function. You also have a quick stop feature to leave the engine on and take the keys. That is real useful if you have young children to take care of. Take key out, leave car and AC/heat on and get children/car seats out/bags and then remotely turn off engine. Power liftgate and hatch release buttons are also programmed to button 1 and button 2 or you can customize to turn on other things.
Or, you can go to KCautosound and the guy is super helpful even if you don't buy from him.
lonewolf78
Aug 18, 2017 07:43 AM
ALR1955
Dec 23, 2016 10:30 AM
Ginther
Escape & Escape Hybrid
Feb 3, 2016 02:06 PM
GTA_G20
Oct 22, 2015 09:00 PM
260karl
Sep 2, 2015 05:32 AM
