New Member with Questions
Old Sep 28, 2008 | 08:28 PM
unibodyslick's Avatar
unibodyslick
New to the site. I have a 63 shortbed unibody truck. I plan to swap in a 5.4 from a 2002 lightning along with the tranny. Any help or info on the swap and wiring would be appreciated. I also plan to install a 04 crown vic front suspension and need some info on that as well. Thanks
Old Sep 28, 2008 | 08:47 PM
BarryMc's Avatar
BarryMc
I can't help you on this subject, but welcome to fte, someone should be along to help anytime now.
Old Sep 28, 2008 | 09:04 PM
unibodyslick
Thanks for the welcome. I hope I can find someone to help. Any guidance or lessons learned would be very appreciated
Old Sep 28, 2008 | 09:41 PM
yotee's Avatar
yotee
i also can't help but would love to see the end result.
Bill W's Avatar
Bill W
Welcome to FTE! From what i have read on this site the Crown Vic front swap will be to wide for that frame, IMO A Mustang II front swap or a Older Dodge K member with torsion bars out of a Duster, Volarie or Dart will fit much better
I dont know much about the 5.4 swap you plan to use
Good luck with your Truck!
Old Sep 28, 2008 | 09:52 PM
yotee's Avatar
yotee
what is the width diff between the 70's frame that is on here and our slicks?
Old Sep 28, 2008 | 10:02 PM
Bill W's Avatar
Bill W
it is 3 inches wider between the 65-66 vs the 67+ trucks, the 64 frame is narrower than the 65-66 trucks
I can not tell you exactly what the differance is.... Garbz will know for sure! prolly others will know too
Found this thread about frame differances
https://www.ford-trucks.com/forums/3...rame-swap.html
Old Sep 29, 2008 | 05:44 AM
ddavidv's Avatar
ddavidv
Do not use a Mustang II. Light duty, not really suitable for trucks.
May want to look at an Aerostar front clip as well as the Dodge Diplomat.
Old Sep 29, 2008 | 05:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Light Duty ain't the word for it. In reality it's a Pinto front clip
What is a 1974/78 Mustang II?
It's nothing more than a re-skinned 1971/80 Pinto.
The only difference between a Pinto and a Mustang II front end is the coil springs used on 1975/78 Mustang II's with 302's.
The 2.3L 4 banger and 2.8L V6 front springs are the same.
Old Sep 29, 2008 | 06:20 AM
Hakk's Avatar
Hakk
I've seen the Dodge Dakota front clip recommended on here, but I have no personal experience with it. I've heard a few people say that the 4.6 mod motor is a tight fit, but that seems surprising to me. I expect you should be able to make the 5.4 fit. I think you should at least measure the major dimensions and compare to your pickup before you buy something.
I haven't done this swap, but I've converted cars to EFI before. My recommendation is to get a complete, running donor vehicle. There are so many odds and ends needed for an EFI conversion that the costs really add up. Even if you buy used and get good deals it costs a lot of money when pieced together.
Old Sep 29, 2008 | 08:48 AM
Flyn66dtmn's Avatar
Flyn66dtmn
welcome to the site, I've always wanted to install a newer model engine in one of my trucks but the electronics of it all scares me to death.especially with all the sensors and hooking it all under the dash.that stuff is out of my league completely. good luck and i hope you keep us posted as i for one am still interested in the process. Dutch
honocor
31
Mar 12, 2020 03:44 PM
mnmharding
1966 - 1977 Early Broncos
Jul 3, 2010 08:59 AM
Aussie 53
16
Mar 15, 2008 10:08 AM
clloyd53
May 14, 2007 09:03 AM
