8.8 Rearend tag info
Old May 20, 2008 | 07:01 PM
351slug's Avatar
351slug
I have a 93 F-150 4x4 5.8 E4od, Can you tell if I have a 7/8 crosspin or 3/4. Im assuming i have a 7/8. Tag info is 3 55 88 3C10. Thanks in advance
Old May 20, 2008 | 09:23 PM
F150xlt's Avatar
F150xlt
Tag shows you have 3.55 gears, 8.8 ring gear, Build date March 10, 1993.
Pinion shaft is 7/8 inch.
I believe Ford stopped using the 3/4 inch pinion shaft on the F150 8.8 rears around late 86 to early 87.
Old May 21, 2008 | 05:07 AM
351slug's Avatar
351slug
I was guessing 7/8, but was not sure. Thanks. Gathering parts for gear change and need a nothced crosspin.
Old May 21, 2008 | 05:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E7TZ4211A .. Pinion Shaft Kit-7/8" (kit consists of shaft and lockpin).
MSRP: $63.85 / ftepartsguy.com price: $45.97
Old May 21, 2008 | 11:47 AM
F150xlt's Avatar
F150xlt
I'd recommend you use a small propane torch and heat up the Pinion Lock Pin to loosen the thread locker before you try to remove the bolt. If you don't there's a good possibility the bolt will shear and you'll need to drill or cut out the remainder of the bolt.
The bolt snapped on me when I was installing my Powertrax locker and I had to use a oxy acetylene torch to cut a groove in the Pinion Shaft to get the remainder of the bolt out.
You should be able to reuse the old Pinion Shaft but always install a new Pinion Shaft Lock Pin which will come coated with thread locker. Torque the new bolt to 15-30 ft. lbs.
Old May 21, 2008 | 12:55 PM
NumberDummy
It's very common for that *&@^$ pin to shear off...very common.
D8BZ4241B .. Lock Pin
MSRP: $2.12 / ftepartsguy.com price: $1.52.
The price is right, but getting the old sheared off pin out of the shaft is a PITA!
Old May 21, 2008 | 06:59 PM
351slug's Avatar
351slug
I got my last one out OK. The spider gears and axle side gears broke ,then the cross pin broke, Grenaded. This truck isnt broke, just putting 4.88s in it. YeeeeHaaaaaw
abrarham
Mar 13, 2013 05:26 AM
6CylBill
Oct 10, 2008 06:30 PM
wallyford
Dec 14, 2006 07:42 AM
mike L
Jul 14, 2006 06:47 PM
grumpyjjo
Bronco II
Aug 21, 2004 11:15 PM
