Offroad & 4x4
radius arm drop brakets?
Old Apr 11, 2008 | 02:34 PM
vic_v8's Avatar
vic_v8
I have a 78 f150 that I'm starting to collect parts for. I'm looking to do a 4" coil lift, with a spacer also, and 4" drop pitman arm. Will I need radius arm drop brackets also?
as a side note, does anyone every body lift this 73-79s?
Old Apr 11, 2008 | 02:41 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
you will need the kit for the 4'' lift. they do not use spacers. radius arm drop brackets come with the kit. body lifts come in 1,2,3 inches.
Old Apr 11, 2008 | 02:54 PM
vic_v8's Avatar
vic_v8
well, I was going to just piece a kit together, a buddy of mine has the coils and arm. I was going to ADD A SPACER to the 4" coil to get 5". a friend has 4" coils, arm drop and NO drop bracket, and claims I don't need one, just seeing what other opinions are.
I am familiar with body lifts, just wasn't sure if anyone actually used them on these trucks. I'm use to the 88-98 chevys that everyone body lifts
Old Apr 11, 2008 | 03:09 PM
78_f800crewcab4x4
if you don't drop the radius arms, your pinion angles and steering will be wrong. i have never seen a spacer used on these. your friend could have done the lift without the drop bracket, but that sounds like a bad idea. i'm sure you could buy the brackets separate anyway. yes, body lifts are common on these trucks.
Old Apr 11, 2008 | 03:28 PM
TN97STROKE's Avatar
TN97STROKE
Some numbers to help.....with every inch of lift you will loose about 1.2 degrees of caster so (4 x 1.2 = 4.8 deg ) so you could get back your caster with C-Bushings I think they offer them in 2deg 4deg and 6 deg (I would go with the 6deg because you will have bigger tires and a little more caster will help a wide tire track better. Now the other way for every inch you lower thre radius arms at the frame you gain about 1.8 deg of caster so (4.8 / 1.8 = 2.66 inches or 3 inches) to get the caster back were it needs to be.
Hope this helps.
Old Apr 11, 2008 | 03:52 PM
chrono4's Avatar
chrono4
Ok.
First off, if you do a drop pitman arm, you have to drop the trac bar too. If you don't, you'll have bumpsteer (read=bad).
Second, don't run the spacers above the spring. 4 inches it quite a bit on these trucks.
Third, no body lifts..
Old Apr 11, 2008 | 05:09 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Im not reading the rest of these post.
Why dont you do it right and buy a 6-8" lift kit and forget about the suck @$$ body lift? Do not substitute spacers in the place of the correct height coils.
Next is a few things that Im not sure youve thought of yet.
8" lift right? what size tires are you intending to run? I bought and quickly sold a 79 F150 a couple weeks ago that had 40s with an 8" lift and no rubs.
What gears are you planning to run? your stock 3.50s wont turn 38-40s worth a crap. Without knowing anything other specs Id look in to 4.56-4.88 gears
What axles do you have? Your D44 wont last 3 seconds with 38-40s and the 9" wont be the happiest either. You could buy chromo shafts but thats not going to help much.
Extended drive shafts? Your stock 1310 Ujoint d-shafts will be too short and too weak for much abuse offroad.
Plus you have engine tranny brakes and steering upgrades to handle the probable tire size.
Welcome to the offroad forum
Old Apr 11, 2008 | 10:12 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
this is gonna get interesting too.
Old Apr 11, 2008 | 10:21 PM
vic_v8's Avatar
vic_v8
easy killer, I have a SAS going on a 91 GMC right now, 14" of lift with 40s, I don't need this truck big, I only want to run 34s or 35s, nothing bigger, the dana 44 and 9" will do just fine, I just wanted to run a hair over a 4" lift, hence a spacer or body lift.
Old Apr 11, 2008 | 10:22 PM
STGFordCrazy04
gotcha highspeed!
Old Apr 11, 2008 | 10:26 PM
crazyredneckanyhow
hey vic ima shoot you an email. i saw your in need of a bed for this trukc and i have jst what ya need
Old Apr 11, 2008 | 10:29 PM
vic_v8's Avatar
vic_v8
location? I'm in NW ILL, I found one in Tenn so far
Old Apr 11, 2008 | 10:31 PM
crazyredneckanyhow
Im in north central wv. Also have a set of doors that are still in the boxes.
Old Apr 11, 2008 | 10:35 PM
vic_v8's Avatar
vic_v8
thats probably to long of a haul for me, at least for this truck
Old May 5, 2008 | 07:32 AM
bronczilla's Avatar
bronczilla
Dont use drop brackets, extend your radius arms.................
