Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Hesitates upon acceleration?
Old Apr 5, 2008 | 04:59 PM
MPDano's Avatar
MPDano
My 2001 V6 Escape hesitates on accleration at any speed and stop. I guess it's missing or something to that affect. I replaced all the plugs, upper intakes gaskets and a collapsed vaccum hose (I think Ford said EGR system). It's the large one that connects to the rear of the intake near firewall. I couldn't buy just the connector hose but had to buy the connector hose, tube and another connector hose (lame). Anyways, the Escape has better power but still misses upon acceration. After stepping on it, it eventually catches and speeds up. What could be my issue?
Old Apr 5, 2008 | 09:38 PM
sfcwoodret's Avatar
sfcwoodret
Could be a dirty injector.
Old Apr 5, 2008 | 09:40 PM
MPDano's Avatar
MPDano
Nope, just figured it out. After all that above plus a DPFE and Fule Filter and still a no go. I took my IAC off and cleaned it out a bit with Brake Cleaner and walla, the missing is gone but I got a funny idle. Going to the Auto place now to pick one up.
Old Apr 6, 2008 | 12:07 PM
MPDano's Avatar
MPDano
Weird, changed out the IAC, now the check engine lights up. Idles high, then drops down after about 30 seconds at 2500rpm. Coming to a stop, it stays around 1200 then drops to normal 750. Was my new IAC defective?
Old Apr 6, 2008 | 08:59 PM
MPDano's Avatar
MPDano
Ok, here the solution. Returned IAC and bought the MAF ($120). Also get the torx with security hole (tool). This is what holds the MAF on. Idles perfect and runs like a champ. Wasted a perfectly good San Diego weekend over this.
Old Apr 8, 2008 | 09:18 PM
winfordr's Avatar
winfordr
Well, it was worth it to me, cause I got a pretty good lesson from it (at your expense). Thanks for sharing.
Old Apr 8, 2008 | 09:21 PM
MPDano's Avatar
MPDano
No prob. Isn't that what forums are about? I hate it when I see posts that start out as a valid problem, but then when the original poster finds the problem, he bails and never tells the fix. Glad to be of help.
Horock
New Member Introductions
Jul 4, 2013 07:44 AM
d5332
1997 - 2003 F150
Jun 4, 2013 11:49 PM
mkrush
Jan 16, 2013 03:12 AM
bubtrauma
May 31, 2003 08:43 PM
