2007 Explorer.... duct work... mixing doors..?
anyways I have read about the 04 having problems with cold air behind the glovebox.. wonder if the duct work is the same???
Cause at the dealer it's normal....
</O
Just got back from the store... 35degrees out, after running it for a while I took my thermometer and checked the very top of the dash..On the pass side far right it was 90 degrees and just a few inches over the top of the glove box it was 60 degrees. My left leg was 90 and my right leg was 72 … pass side under the dash was 114 and on the drivers side it was 72…
<O
</O
Plus you can feel a cold draft coming from the steering column where the release is for the tilt.
<O
</O
That’s normal I guess….
<O
</O
It really burns my *** is when they don’t take the time to diagnose the problem, that’s the one thing I was well-known for when I worked for Exxon as a tech… verify the complaint… people just don’t make this **** up… drive it …drive it everywhere you go until you can verify the complaint… I know when I worked at Subaru warranty would only pay ½ hour for diagnostic time and then what ever they paid for that particular part to be replaced… so I’m sure they drove it around the block and said “it’s fine nothing wrong with it”
<O
</O
I asked the service writer if they pulled the dash apart to check the actuators or moving doors, he said they can’t verify the complaint so they can’t rip and tear… because someone has to do it for nothing… that’s the biggest problem, it might take 4 hour to find it but they only get .5 hour pay for it… so they take the .5 and tell you your basically crazy and there is nothing wrong…
here is some stuff I found
<TABLE class=MsoNormalTable style="WIDTH: 100%; mso-cellspacing: 0in; mso-padding-alt: 0in 0in 0in 0in" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR style="mso-yfti-irow: 0"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" colSpan=2>
</O
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; WIDTH: 100%; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" vAlign=top width="100%">It's winter here and we've just bought a 2005 Explorer Limited.While driving it - we're noting a VERY noticeable cold draft coming from the glove box. Much like having a window down - and it's downright uncomfortable!
Can anyone give me any hints as to what is going on? What could be the problem?<O
</O
<O
</O
</TD><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" vAlign=top>
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" colSpan=2>
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; WIDTH: 100%; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" vAlign=top width="100%">We have 2004 Explorer with the exact same issue. I don't have a solution but wanted you to know it wasn't just you. We also have a low volume of air coming through our vents on all settings and speeds. I read that could be the result of something being sucked in (napkin) from the glove box. Apparently there is an intake under there. I will dig into that and see what I can find. It might shed some light on why we're getting the air leak. Drives my wife nuts in the cold weather.<O
</O
<O
</O
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" colSpan=2>
</O
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; WIDTH: 100%; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" vAlign=top width="100%">I have an 02 Explore XLT and am having the same issue. I stuffed a towel in there to help keep some of the air at bay. I'm taking it to the dealer in the next few days so hopefully they will have a fix and I can pass it on.<O
</O
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" colSpan=2>
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; WIDTH: 100%; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" vAlign=top width="100%">So I just now took my truck into the shop. They told me I was going to have to have my "max recirculating door" replaced. They said eventually it would wear out and then I wouldn't have heat or A/C. Cost $850 because they have to remove the dashboard to replace it. Hope this helps!<O
</O
<O
</O
</TD></TR><TR style="mso-yfti-irow: 8"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" colSpan=2>
</O
</TD></TR><TR style="mso-yfti-irow: 9; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; WIDTH: 100%; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent" vAlign=top width="100%">Can anyone tell me what all needs to be done to remove the dash on a 2004 Explorer. Afraid I need to fix the blend door to stop the cold air around the glove box. Suggestions? <O
</O
</TD></TR></TBODY></TABLE>
It turned out the recirculate air door that swings back and forth to select fresh air or air from inside had simply fallen off inside my ventilation system, allowing a path straight from outside into the airbox below my passenger side dash. You could drop the blower motor/ fan and reach up in there and feel/ see it clunking around in the box, so I'm not sure why your dealership techs didn't think to do that. That part takes like 10 minutes...
Unfortunately there is no way to replace the door and connect it back to the vacuum motor properly without pulling the whole dash apart and cutting through a grate on the airbox to access it.
So that's what I did, and it took all of a Saturday afternoon to do. When it was apart it looked like the door could slide back and forth on it's hinge point too far, which is what caused it to slide out of place and fall down in the first place, so I threw a few washers in on the pivot point to shim it up. Been fine ever since, but was a pain to get the dash all apart and back together with no squeaks.
To pull the dash you have to take the center console apart and disconnect the steering column, pull the radio and climate control panel, pull all trim around the dash, disconnect a bunch of wiring harnesses, etc. Then there's a couple big bolts that hold the dash in. I pulled it all back only far enough to access the climate control unit and do the repair, I don't think I had to disconnect everything. It was a long time ago so I don't remember completely.
Sounds like this problem is more common than I thought.
