A/C Duct
Old Dec 23, 2013 | 09:01 PM
79FordBlake's Avatar
79FordBlake
A/C Duct
I know its been discussed before and nobody is making them currently but does anybody know anything that will work? The center duct and driverside duct is not salvagable at all on the 78 Bronco I just bought. It would be great to have the heat and a/c blow out the vents instead of just everywhere behind the dash and lower vent.
I took the current ducts out because they looked about like a slinky all the material is gone from them its just metal. Everything in the junkyard looks the same.
Old Dec 23, 2013 | 09:10 PM
Ordnance's Avatar
Ordnance
I've got the same problem, A fix i discovered via a thread on here, is this:
Take the remaining coil and clean it up as best you can.
Buy some vinyl fabric and cut it to length of the coil.
Spray with headliner adhesive
Wrap the coil in the fabric, let it cure.
reinstall.
Old Dec 23, 2013 | 10:46 PM
Mustangking1's Avatar
Mustangking1
You can also buy a section of vinyl vent hose 4inches wide for the drivers side vent. You can get it from your local hardware store. The middle vent you will have to do the above described way to fix it!
Old Dec 23, 2013 | 10:55 PM
JWC 3's Avatar
JWC 3
I used vent hose and some drain adaptors from ACE Hardware to do my driver and passenger vents . Still working on my center vents .
Old Dec 24, 2013 | 02:12 AM
Ordnance's Avatar
Ordnance
Does anyone have a source on the vinyl vent hose? The only stuff i found online smaller than a dryer vent was $120 for 8' i neither need nor want to spend that much.
Old Dec 24, 2013 | 02:15 AM
JWC 3's Avatar
JWC 3
LMC did list the hose . I adapted dryer vent hose for mine .
Old Dec 24, 2013 | 03:26 AM
Ordnance's Avatar
Ordnance
Ebay currently has some listed. however unless it's in the current LMC catalog, which i don't have, It's not listed.
Old Dec 24, 2013 | 08:21 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Can you get some out of a newer 2000+ JY Ford truck and adapt to your older vent ends? I have heard of that being done.
Old Dec 24, 2013 | 10:42 AM
79FordBlake
I seen those on ebay last night. I wonder why some ducts are solid plastic with a elbow on it? They should all be like that. On mine from the lower vent all the way to driver vent its that material that deteriorates with age.
Old Dec 24, 2013 | 10:46 AM
84espy's Avatar
84espy
Has anyone checked shop vac hoses? They come in a variety of sizes.
Old Dec 24, 2013 | 11:05 AM
77&79F250's Avatar
77&79F250
Some 78/79 Bronco's have the solid plastic piece going to the drvs vent.
The top flex piece came from a 73 F100 and the bottom plastic piece came out of a 78 Bronco.
Sorry parts already sold.
Old Jan 16, 2014 | 07:22 PM
79FordBlake
I hit the jack pot on vents the other day. I got 3 driver side vents and 3 middle vents. One of the driver side vents was solid plastic, that's the one I used. Its great having all the vents work.
Old Jan 16, 2014 | 07:57 PM
SuperDuty93's Avatar
SuperDuty93
http://nostalgicac.com/duct-hose-vents.html
Nostalgic air makes them. They take round hose into the back but I'm sure they can be modified.
Old Mar 12, 2022 | 06:53 PM
jackietreehorn's Avatar
jackietreehorn
Does anyone have the dimensions of the infamous rectangular center / middle A/C duct ? I am scheming up a good and cheap solution for all.
Old Mar 13, 2022 | 10:54 PM
77&79F250's Avatar
77&79F250
I have one in my parts shed, I can go measure tomorrow for you.
