5.0 to 4.9 swap mess
My friend swapped a 1992 4.9 into a 1988 f-250 that used to have a 5.0 in it. It didn't run when he was done, so he gave it too me. He used the 1992 computer and the 1989 distributor out of a different truck. Now the bad part. The fuel pump doesn't work. Any connection? Anything else that I should check or do?
Received 1,032 Likes
on
It's likely the computers are wired differently.. pretty sure by '92 Ford had moved the TFI module to the fender off the distributor.. and the module may be different as well. You should have enough wires in the 5.0 harness to make it work, but you'll have to dig up pinouts for both systems and swap some pins in the EEC connector. Maybe somebody else will stop by with links to these diagrams....
www.fordfuelinjection.com might have wiring info for this setup. If you can get the proper year efi harness for the 300-6 and computer from a yard that should help. the wiring from an f150 may also work.
also check the inertia switch under the dash if it trips the pumps wont run at all
hreyesg
02-07-2013 07:17 PM
strokin'_tatsch
02-22-2012 06:27 PM
spudman01
10-08-2010 01:56 PM
jonathan89
12-09-2005 06:14 AM
