running a return line
Old Jan 9, 2008 | 05:38 PM
ncl's Avatar
ncl
I got a 77 f150 that I may add fuel injection to and I would have to add a return line couldnt I just tee into the rubber vent hose that goes into the filler neck and utilize it or would that not work. I am just not sure if the metal is thick enough in the tank to tap it for threads to add a fitting.
Old Jan 9, 2008 | 07:10 PM
ford_boy_1996's Avatar
ford_boy_1996
You could drill a hole in the tank and put in a rubber seal with a fitting. But you would have to take the tank out and drain it...I dont see any prob with putting a T in your vent hose either
Old Jan 10, 2008 | 03:16 AM
LxMan1's Avatar
LxMan1
I agree, it should work fine in the vent hose.
Old Jan 10, 2008 | 03:33 AM
greythorn3's Avatar
greythorn3
i put a line into my filler neck also when i put a diesel in my 75 ford truck, works great.
Ray
Old Jan 10, 2008 | 02:40 PM
ncl's Avatar
ncl
hey thanks guys that will make it much easier installing the fuel injection. I just didnt like the fact of not having much meat there to thread anything.
Old Jan 10, 2008 | 04:01 PM
greythorn3's Avatar
greythorn3
when you install it in to the filler neck make sure you bend it at 90 deg and point it towards the tank.. also put it as low as possable mine interferes with my pumping of fuel somtimes.
Ray
Old Jan 12, 2008 | 01:12 PM
ncl's Avatar
ncl
I wasnt going to put it directly in the filler neck I was going to tee into the smaller rubber vent line coming out of the sending unit that tees in to the filler neck.
pickenspolitics
18
May 31, 2014 09:15 PM
bkuuz1
Aug 22, 2012 08:51 PM
rich250
Jun 19, 2008 07:01 AM
Bear Hunter
Nov 11, 2005 01:43 AM
orange78oval
1978 - 1996 Big Bronco
Feb 9, 2004 02:20 PM
