Vibration / hesitation / surging at low rpms
Old Jan 1, 2008 | 02:50 PM
speedworks's Avatar
speedworks
Can anyone help? I have a 2000 V10 X, and all of sudden I am getting a good vibration at low rpms (1000-2000 is the worst), and any gear, during Acceleration. Under hard acceleration, it appears to go away, and it gets better above 3000 rpm, but I can still feel it. It also will do it in 4x2 or 4x4. It happened while the truck was sitting for a week (on vacation). If I coast (no gas), there is no vibration. It feels like there is a hesitation going on as well, causing the vibration. I do know it is NOT the tires. Any help would be appreciated. Thanks.
Old Jan 2, 2008 | 12:15 AM
Monsta's Avatar
Monsta
Sit. Stay.
I would first suspect a (or multiple) bad COP (Coil on Plug).
Old Jan 2, 2008 | 12:35 AM
aortizexcursion's Avatar
aortizexcursion
Definately check the COP. I've had COP's go bad before and your description of the problem is pretty much what I experianced. Just recently I replaced all 8 (I have a V8 Excursion) of the COP's, it was about $400 total for all 8.
Old Jan 4, 2008 | 12:04 PM
speedworks's Avatar
speedworks
So, it ended up being some coils (2 of them) - took it somewhere to have them replaced. What makes these go bad? Are they easy to change - any how-tos? As only 2 have been replaced, I still have 8 more opportunities. Thanks.
Old Jan 4, 2008 | 02:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Heat & age are usually the culprits. Depending on the miles it may not be a bad idea to replace all of them. Make sure new boots and some dialectic grease is used.
Old Jan 4, 2008 | 03:33 PM
BAJI26's Avatar
BAJI26
Couldn't it be the gas also?
Old Jan 5, 2008 | 02:27 AM
Monsta's Avatar
Monsta
Sit. Stay.
That poops out the COPs? Never heard of that but I guess anything could be possible.
Old Jan 5, 2008 | 10:00 AM
speedworks's Avatar
speedworks
91k on the odometer. As it cost enough for 2, I don't want to do the others unless I can do it myself - do you know of any DIY writeups?
Old Jan 5, 2008 | 02:09 PM
Monsta's Avatar
Monsta
Sit. Stay.
Check the V10 forum or even the 5.4L V8 forum since they are the same.
It is a DIY thing and very easy to do.
Old Jan 5, 2008 | 08:45 PM
BAJI26's Avatar
BAJI26
When I was moving from FL to TN after filling up at a chevron station a few miles down the road the more I press the pedal the slower it will go and it wouldn't even go above 40 on I75, I call the dealer on the road and they said it sounded like the tranny, I then called my friend and he said that that happened to him once and he added some additives to the gas and it was ok, I did that and it started driving better. The next morning and for a few weeks after that is was bucking, black smoke, and hesistation then I read here about the COP issues, so I was gonna replace them then all the weirdness stopped. Since it stopped it didn't happen again. All because of a tank full of bad gas.
Codyaye
Feb 24, 2017 02:04 PM
expo54bx
Oct 2, 2010 12:52 PM
mjs
Jun 21, 2005 09:46 AM
grcutter
Jul 15, 2004 06:36 PM
jhromy
Apr 12, 2004 02:16 PM
