Oasis Report
Oasis Report
I am looking at an F-450 on the dealer lot VIN 1FTXW42R58EA52058.
Any info willbe helpful. Thank You
I am looking to purchase this truck but would like to know the history before getting serious. Dealer is looking to move it from what the salesman has stated. I will be pulling a fifth wheel to Alaska this summer. What rear end is in the truck? Shold I look for something else maybe even order one?
Oasis Report
Originally Posted by iceman7329
Simply put, Id stay away from that truck.
![Talking](images/icons/icon10.gif)
Originally Posted by jam105
Why don't you ask the Dealer for a OASIS Report on the vehicle. They should be willing to provide you with this...Could be very minor issues.
I did ask the dealer if he could give me the Oasis report and he nicely stated no. I do not think he is trying to hide anything just would prefer not to give it out. This does not surprise me from a dealer as they want to move the vehicle. I suspect that there are a few warranty claims that some might percieve as bad news either way. My biggest concern is if the issues are engine or transmission related. I have no problem if a lock was stuck or the air malfunctioned . The truck will still have a warranty after my purchase. I would stay clear if the vehicle has had several engine issues. I would just like someone to print the Oasis report and send it to me or post either way and this could all end pretty quickly.
It would appear the Dealer does not want to sell it that bad..I'd tell him if you want me as a customer then give it to me...Several other Dealers..If they refuse that could be a sign it is a Dealer you would not want to deal with as you may have issues with them and customer service.
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top width="99%" colSpan=2>I can't show you the whole Qasis but these are the items that are on it. Hope it helps. Like i said before nothin major.
5040 FUEL LEAK DIAG FOUND FUEL LINE LEAKING AT THE PUMP R&R CAB TO GET DO T HE RIGHT HAND LINE REPLACED LINES AND RETESTED ALL IS PASSED NO LEAKS ALL IS OK NOW
</TD></TR><TR><TD width="1%"></TD></TR></TBODY></TABLE>
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="99%" colSpan=2>4981 FUSE (14526) 28 WF VERIFIED TOW-HAUL BUTTON CONCERN.PERFORMED BODY -CH ASSIS-ELECTRICAL CONCERN.REPLACED FUSE 35 10 AMP IN SMART JUNCTION BOX.VERI FIED PROPER OPERATION.</TD></TR><TR><TD width="1%"></TD></TR></TBODY></TABLE>
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top width="99%" colSpan=2>4981 DRIVESHAFT (4R602) D9 LABOR OP 071603A WF VERIFIED CONCERN FROM DRIVEL INE.REPLACED DRIVE SHAFT PER TSB 07-16-3.</TD></TR><TR><TD width="1%"></TD></TR></TBODY></TABLE>
OIL EVERYWHERE, ALSO ON TAILGATE, CUSTOMER WASHED OFF. REPLACED ENGINE DI P STICK TUBE O-RING
2132 FUEL LEAK DIAG FOUND FUEL LEAKING FROM FUEL LINE THAT RUN FROM PUMP TO RH HEAD REPLACED AND RETESTED ALL SEEMS OK NOW
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top width="99%" colSpan=2>2135 WF08 9E731 42 M-TIME .3 TO REPAIR CONNECTOR PINS AT SENSOR. ROAD TESTE D VEHICLE FOR A ABS LIGHT COMING ON VERIFIED ABS LIGHT STAYS ON. CK CODES, CODES C175 AND 1237, REAR SPEED SENSOR FUALT. PIN POINT TEST, FOUND ABS CO NNECTOR C 455 PINS NOT SEATED TO SENSOR, SECURED PINS ONE AND 2 IN CONNECTO R. CLEARED CODE AND ROAD TESTED OK</TD></TR></TBODY></TABLE>
Just on principal, if the dealer is saying NO to giving you an Oasis, I personally would have to wonder why? What's the big deal if you're the potential buyer? Maybe someone more knowledgeable than I could explain that. I can understand them not wanting to do this for every used vehicle, but if that is the only thing between you and the "deal", what 's it going to cost them?
Oasis Report
oasis report
I live about 300 miles from the dealer and before I go look at this truck I would like to have an oasis report. something just does not seem right. vin # 1FTSW21R28EA40711 thanks in advance to you sanddemon08. you can email the results to booked15@yahoo.com.
thanks again
Tom
thanks again
Tom
thanks again
Tom
thanks again
Tom
