I am looking to purchase this truck but would like to know the history before getting serious. Dealer is looking to move it from what the salesman has stated. I will be pulling a fifth wheel to Alaska this summer. What rear end is in the truck? Shold I look for something else maybe even order one?
Is this just an opinion or have you seen the Oasis report. If you have seen the Oasis report Thank You. If you are going off of your opinion why do you thank I should stay away from this truck and Thanks for your opinion better to speak than say nothing at all.
Why don't you ask the Dealer for a OASIS Report on the vehicle. They should be willing to provide you with this...Could be very minor issues.
I did ask the dealer if he could give me the Oasis report and he nicely stated no. I do not think he is trying to hide anything just would prefer not to give it out. This does not surprise me from a dealer as they want to move the vehicle. I suspect that there are a few warranty claims that some might percieve as bad news either way. My biggest concern is if the issues are engine or transmission related. I have no problem if a lock was stuck or the air malfunctioned . The truck will still have a warranty after my purchase. I would stay clear if the vehicle has had several engine issues. I would just like someone to print the Oasis report and send it to me or post either way and this could all end pretty quickly.
I would but I do not have access to it..
It would appear the Dealer does not want to sell it that bad..I'd tell him if you want me as a customer then give it to me...Several other Dealers..If they refuse that could be a sign it is a Dealer you would not want to deal with as you may have issues with them and customer service.
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top width="99%" colSpan=2>I can't show you the whole Qasis but these are the items that are on it. Hope it helps. Like i said before nothin major.
5040 FUEL LEAK DIAG FOUND FUEL LINE LEAKING AT THE PUMP R&R CAB TO GET DO T HE RIGHT HAND LINE REPLACED LINES AND RETESTED ALL IS PASSED NO LEAKS ALL IS OK NOW
2132 FUEL LEAK DIAG FOUND FUEL LEAKING FROM FUEL LINE THAT RUN FROM PUMP TO RH HEAD REPLACED AND RETESTED ALL SEEMS OK NOW
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top width="99%" colSpan=2>2135 WF08 9E731 42 M-TIME .3 TO REPAIR CONNECTOR PINS AT SENSOR. ROAD TESTE D VEHICLE FOR A ABS LIGHT COMING ON VERIFIED ABS LIGHT STAYS ON. CK CODES, CODES C175 AND 1237, REAR SPEED SENSOR FUALT. PIN POINT TEST, FOUND ABS CO NNECTOR C 455 PINS NOT SEATED TO SENSOR, SECURED PINS ONE AND 2 IN CONNECTO R. CLEARED CODE AND ROAD TESTED OK</TD></TR></TBODY></TABLE>
Just on principal, if the dealer is saying NO to giving you an Oasis, I personally would have to wonder why? What's the big deal if you're the potential buyer? Maybe someone more knowledgeable than I could explain that. I can understand them not wanting to do this for every used vehicle, but if that is the only thing between you and the "deal", what 's it going to cost them?
Thanks to everyone especially SandDemon08. I have decided not to purchase the truck after talking to the dealer one last time. You get feelings in life and something told me to stay away from this one the hunt continues. Thanks again to everyone this forum was a great help.
I live about 300 miles from the dealer and before I go look at this truck I would like to have an oasis report. something just does not seem right. vin # 1FTSW21R28EA40711 thanks in advance to you sanddemon08. you can email the results to booked15@yahoo.com.
thanks again
Tom
Well, thiers nothin to email,oasis is clean no repairs ever done,no problems.
