Truck Won't Start
Truck Won't Start
Today I installed a set of backup lights onto the truck. I found the wire that feeds the backup lights to the trailer plug and tapped into it.
When I put it into reverse the lights work great.
Truck turns over good so it is not battery/starter. It will just not start.
When I let it sit for 30 seconds I get a symbol looks like a wrench on the display.
Engine turns over fine. Tried both keys also.
Checked all fuses.
No issues found under hood or in cabin…Unhooked both batteries and left them unhooked for 10 minutes.
Pressed the fuel reset on passenger side.
Still same problem
Any thoughts?
Checked all fuses.
Still same problem
Any thoughts?
Hope the dealer got your truck going today; let us know what they find.
Found this TSB 07-26-2 December 20, 2007
"Some 2008 F-Super Duty vehicles built prior to 8/20/2007 equipped with a 6.4L diesel engine may exhibit a lack of power or no start with possible DTC's P0003, P0004 and P0091 caused by circuit CBB12 at the high pressure pump gasket grounding to the high pressure pump body (may also result in fuse 74 being blown)."
Good luck.
Bob
Good luck.
Bob
Yep, the high pressure fuel pump. They don't actually replace the pump, just the wiring harness; cab off repair....
My build date was 8/28/07 so hopefully this is one I will not worry about.
Worse kind of problem for someone to have as the no start may leave you stranded and sometimes it might be the worst of times or places. Hopefully it will not occur on too many vehicles.
Bob
Bob
Well...Talk about feeling like a dope!...
Fuse 74 was the culprit....Man I looked at this fuse twice and did not see it blown. Once they hooked it up to the computer they went right to it....
I hate this as I cost a bunch of money because I did not catch this!
They checked to see if it had a ground that would cause this but they did not find one....Will keep some extra fuses on hand and watch this....
Well I'm glad your up and running but I would be a little nervous. When a fuse blows theres usually a reason. Just to be safe I'd write down the number of that TSB & throw it in the glove box just in case. I'm not one to put a lot of faith in coincidence and it sounds like Bob may have diagnosed your problem. Fuse 74 fits. Did they pull any other codes? You might consider checking fuses next time with a multi-meter. Sometimes it's hard to tell if those things are blown.
Keep us posted if it comes back. Here's hoping it was a fluke and you never have any more problems. Good Luck.
No I did not use my multi meter..I'm sure I would have found it if that was the case...Just eye balled it...Guess these old eyes ain't what they use to be as they said they could see it...
No other codes were pulled. I mentioned the TBS and they said they found no ground faults. If it blows again they said they would process it for the TBS....
websurfer
1997-2006 Expedition & Navigator
19
02-21-2024 06:19 PM
Thomas White
07-11-2015 01:25 PM
Grinder Man
10-10-2014 09:35 AM
