Ford pulled these codes off my X today...suggestions?
Old Nov 13, 2007 | 05:44 PM
SZAlbNM's Avatar
SZAlbNM
2000, 5.4, 122K miles.
Check engine light came on so I took it to the Ford shop. P0171, P0174, P1132, P1131. They told me replace MAF, repair vacuum leak in pcv hose, replace bad O2 sensor (I just replaced both with Bosch OE 10K ago, only had 2 upstream), COP boot cracked causing misfire, replace air filter.
I'll do the work myself. Do these codes indicate anything more specific or different from the verbal recommendations?
Thanks,
Steve
Old Nov 13, 2007 | 07:22 PM
1's Avatar
I dont have the time to look up all the codes right now, but more then likely one problem triggered all those codes. Try to see if they are related somehow or if one could effect the rest etc.
Old Nov 14, 2007 | 01:51 AM
Monsta's Avatar
Monsta
Sit. Stay.
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
Sounds like your o2 sensor is bad. Weird.
For your other two look here http://www.obd-codes.com/trouble_cod...gen-sensor.php
Clean your MAF before you replace it. Other than that I'd do exactly as the recommend and go from there.
Old Nov 27, 2007 | 08:38 PM
nzirbel's Avatar
nzirbel
Save Money
1. Clean MAF sensor with quick dry electronic cleaner
2. Check pcv system very carefully for cracked hoses. Fix.
3. Reset computer, drive it and that shoud take care of running lean on both banks problem. Worked on mine and haven't seen CEL on since.
$3.00 fix
Hope it is that easy for you..........
killthe6.0forddiesel
Sep 8, 2011 06:08 AM
dafella
1997 - 2003 F150
Apr 23, 2008 10:10 AM
radunegruion
3.8 & 4.2L V6
Feb 12, 2007 08:09 AM
Matts66
Mar 17, 2004 07:49 PM
Sphinky
Jan 4, 2003 07:53 PM
