2001 Exploder NO HEAT
Old Oct 15, 2007 | 06:58 PM
2003 F.E. Supercrew's Avatar
2003 F.E. Supercrew
My wife's exploder has no heat. Did the normal changed thermostat. Checked blem door , it's okay. Took heater hoses off, poured water thru it and it flowed
just fine.
Took a clear line and installed it in place of the heater core and antifreeze does NOT flow [it will a little with higher rpm]. Confused.
What next???
PUNT ?? or
SHOOT IT
Have any suggestions ??
Old Oct 16, 2007 | 02:33 PM
fordguy55's Avatar
fordguy55
It's possible the water pump impeller has broken free from the shaft. Any overheating?
Old Oct 16, 2007 | 08:52 PM
2003 F.E. Supercrew
No problems with over heating....Is there maybe a valve that opens and closes off the water flow thru heater core or does the water constantly flow thru it ???
Roper53
Dec 9, 2007 12:20 PM
66gpw
Feb 8, 2007 08:33 PM
78workhorse
Pennsylvania Chapter
Sep 4, 2006 09:26 AM
