Dana 44 From Canada?
Old Jul 27, 2007 | 01:01 PM
The67Beast's Avatar
The67Beast
Hi guys.
I want to throw this out there and see what you think. I have a 67 F-100 4X4 that was built in the Ontario, Canada Plant. As far as I can tell everything is stock. The front is a Dana 44. However, it is a High Pinion unit. This one is fairly old since it has king pins in the knuckles and not ball joints. Some Bronco guys say it's a D44 with D30 knuckles, similar to the very early Broncos. Anyway, I have been trying to reference the build number on the front of the axle tube with no luck. I have been told that all Dana 44 during this time period had a 7 digit number that generally started with a 6. My unit has the following number...
113701117A5
Did the Canada trucks use a different series of numbers on the axles? Has my truck had an axle swap somewhere along the way? Can anyone decode my number?
leroy78
Feb 10, 2013 12:03 AM
Tomahawk2506
Jun 16, 2012 04:46 PM
crazed87bronco
17
Jun 28, 2011 07:01 PM
bigblue
Jun 8, 2003 10:15 AM
ford_nut
Jan 28, 2002 09:03 PM
