Sponsored by: Auxito
Tow Hitch?
Old Jun 19, 2007 | 08:03 AM
Stangfire's Avatar
Stangfire
Tow Hitch?
What rating of tow hitch can I put on my truck?
It's a 2003 F150 4x4, Ext. cab, 5.4L.
In the future I may want to pull a boat or camper. Right now I only pull two snowmobiles.
Thanks.
Old Jun 19, 2007 | 12:12 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A class III should be fine, but you can get a Class IV and V that will be stronger.
Me, personally, I like the bigger hitches because they use more surface area of the frame to mount to, they are thicker, and they use more/thicker bolts. This is good for me because I do a lot of fourwheeling, and Im often yanking someone out of a mudhole...or getting yanked out. Hahaha...
Typically...
Class III - 5,000lbs/10,000lbs weight dist.
Class IV - 8,000lbs/12,000lbs weight dist.
Class V - 15,000lbs/17,000lbs weight dist.
Michel153
Oct 9, 2014 07:41 PM
Mustang1966
Jul 30, 2010 06:52 PM
tdford
Dec 21, 2004 09:34 PM
ryanben
All Things Towing
Apr 12, 2003 04:22 PM
Tonytheman
All Things Towing
Apr 6, 2003 01:42 PM
