Ford F150 Transmission Problem codes P0712, P1783
</O
Can some one here shed some light on an issue that I am having with my 2003 F150 5.4L V8? This is my 3rd F150 from Ford in the last 8 years so I am a repeating customer of Ford. I started seeing my Overdrive light flickering when it should not be, and it does this whether it is in the on position or off position. The OD still works but the light flickers… I noticed that the shifting started to get a little rough so I decided to take it in and get the transmission fluid/filter changed. I was informed by the mechanic that he pulled the following diagnostic codes: P0712 and P1783.
<O
I was told that the codes and symptoms were indicative that my transmission needs to be replaced which obviously did not make me happy with only 63k miles on the vehicle. The dealer wanted another 1,200.00 to tear apart my transmission so they could fully diagnose the issue and I said no way! That’s just to tear it apart not fix the problem. (I was quoted like $3000.00 for a rebuilt transmission.) I then contacted Fords Corporate Customer Service and explained the situation. The Ford customer service rep and manager then told me they will not consider assisting me until they completely diagnose the issue, meaning I pay the money to have the dealer rip apart my transmission to tell me its bad. Makes absolutely no sense to me as a re-occurring ford customer for almost a decade.<O
</O
I spent time on-line researching the codes (P0712 and p1783) and found numerous of posts were Ford owners were having the same issue. Most of them were either told to replace the Sensor/wiring kit for the transmission as that is what the codes refer to as the problem. It appears that when they replaced the sensor, the problem went away and then came back??? Seems to me that this is a defect issue and ALOT of Ford owners are very UN happy about this issue from what I have read all over the internet. Why doesn't Ford address this issue as it seems to be a very wide spread problem in ALOT of different vehicles using this transmission. You would think that FORD would want to assist or Help re-occurring customers when a major issue like this is brought to there attention.
If anyone has any information regarding this issue, I would surely appreciate it. Thanks in advance for your time and comments.
How do you use your truck? Do a lot of towing? The DTCs translate as shown below. I expect that this is why the dealer needs to pull it down, to see what has been damaged with the overheated transmission.
P0712 Transmission Fluid Temperature Sensor Open
P1783 Transmission Over-Temperature Condition
Good Luck!
However I only use the truck for normal driving back and forth to work and I don't use it to tow or haul anything. I did look up the codes and I found the same as you had mentioned plus this info below:
P0712 - Voltage drops across TFT sensor exceeds scale set for temperature of 157 degrees C.
Symptoms = Firm shift feel
RESOLUTION = Replace TFT sensor/wiring
P1783 - Transmission fluid temperature exceeded 127 degrees C.
Symptoms = Increease in EPC Pressure
Resolution = Wiring or TFT Sensor clogged cooler
<SUP></SUP>
Good Luck!
I talked to the mechanic I originally took it to have it serviced and he stated that there was fluid sensor wiring kit and suggested that the solenoid packge be replaced with the senor/wiring. He quoted me just over $535.00. I just hope that replacing this resolves the issue. I have seen some people post on-line that they (The dealer) replaced the sensor and the problem went away but then came back and the dealers had no clue on how to resolve the problem.
