door ajar and dome light
Old Apr 19, 2007 | 10:50 AM
uppernorth's Avatar
uppernorth
i have a 2000 f350 . lately my door ajar lite stays on . when it does this my dome light stays on also . but when i hit around 15 mph the dome go out then when i slow down under 10 mph it comes back on at night it drives me nuts on off on off. also after turning off the truck the dome lite stays on for around 15 minutes. whats up?
Old Apr 19, 2007 | 10:54 AM
6.0KEVIN's Avatar
6.0KEVIN
Try Some Wd-40 In Both Latches And Slam The Doors Shut A Few Times To See If That Helps. The Door Ajar Switches Are In The Latches And They Tend To Get Dry And Stick At Times.
Old Apr 19, 2007 | 07:13 PM
rcorcich's Avatar
rcorcich
Thanks Kevin,
I was having a similar problem, and tried your fix.
it seemed to work , i'll let u know in a coulple days.
Thanks,
Rich
Old Apr 20, 2007 | 11:58 AM
uppernorth's Avatar
uppernorth
wd 40 and slamming no change whats next?
Old Apr 20, 2007 | 02:18 PM
Franklin2's Avatar
Franklin2
Change the door switch. You have to get inside the door where it's located near the latch.
Old Apr 20, 2007 | 07:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
This is a very common problem with the newer Fords. Keep replacement switches handy...
Old Apr 22, 2007 | 03:17 PM
uppernorth's Avatar
uppernorth
took 3 days after soaking with wd40 now works fine. thanks for the info.
Old Apr 22, 2007 | 08:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
Next week it will be back out...
Old Apr 23, 2007 | 11:14 AM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
I am having the same problem with the fifes 97 Taurus. I would be interested to know a good fix too. Mine is a little more intermitint. If I hit the door at the handle with a DEAD BLOW hammer on the latch it usually fix's it.
Old Apr 23, 2007 | 05:24 PM
Franklin2's Avatar
Franklin2
Replace the switch. Some people have good luck with the wd40 trick, and some don't.
Old Apr 28, 2007 | 06:39 AM
sonchaser91's Avatar
sonchaser91
I am having a similar problem on my 03 f250 powerstroke. The door ajar light stays on ALL THE TIME. And the dome light and cargo light never come on when I open any of the doors, but I can turn them on with the overhead switch so I know that the fuse isn't blown. Will the wd-40 solve this problem as well or do I need a new switch, or do I have a different problem all together?
Old Apr 28, 2007 | 02:13 PM
Franklin2's Avatar
Franklin2
I would say you have the same problem. Are you sure the lights you are turning on manually are the same as the domelights? If they are the maplights, they are on a different circuit.
Old Apr 28, 2007 | 02:30 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
WD40 is danged cheap to try...soak the affected door latch (not the frame latch) and open/close the door a number of times. If that doesn't fix it, resoak with WD40 and let it soak in for a few days - most times it'll all of a sudden "fix" itself. While you are waiting for this to fix itself, soak all the other door latches.
Old May 3, 2007 | 07:52 PM
sonchaser91
The wd40 still hasn't kicked in so I guess I am going to have to replace the switch. But I also checked my manual for the location of the dome light fuse just in case. I couldn't find "dome lights" or "interior lights" anywhere in the listing of the fuse locations. Can anyone tell me what the number is for the location of the dome lights fuse in the fuse panel? It is an 03 F250 7.3 Powerstroke.
sbappleg8
1983 - 2012 Ranger & B-Series
15
Aug 2, 2017 11:45 AM
rpstrong
Dec 13, 2013 06:47 PM
socalarcade
Dec 12, 2010 05:17 PM
bentheplumber
Jul 5, 2007 12:04 AM
