flaky high beam
Old Apr 25, 2007 | 10:27 AM
aurgathor's Avatar
aurgathor
flaky high beam
I have a '95 Bronco, and the high beam behaves very strangely -- sometimes it simply doesn't come on, other times it just goes dark. The blue indicator on the dashboard stays ON, however. That seem to indicate that the switch in the steering column is probably OK.
Questions: does anyone had a problem like this? And if so, what had to be done to fix it? If no answer for the previous question, how is the hi-beam switched? Is there a relay somewhere, or the high bean is switched directly from the steering column?
TIA
Old Apr 25, 2007 | 12:49 PM
Franklin2's Avatar
Franklin2
I looked at the diagram, and you are correct, the blue light is after the switch, so the switch must be ok. After the switch, the wiring runs out to a main connector on the firewall, near the brake booster area. You might want to check this plug. If the lowbeams are ok, then we can assume the ground is good at the headlights.
Old Apr 26, 2007 | 11:07 AM
aurgathor's Avatar
aurgathor
The low beams are fine. I'll check that plug. Since you didn't mention it, I assume there is no relay in the path.
Old Apr 26, 2007 | 12:14 PM
Franklin2's Avatar
Franklin2
No relay on yours. The lightgreen/black is the high beam in this diagram.
http://www.autozone.com/images/cds/g...3d800a3a5f.gif
Old Apr 26, 2007 | 01:13 PM
currituckF150's Avatar
currituckF150
I would still check the multifunction switch and I would also check the headlight switch & plug as they have had a problem with melting.
Old Apr 26, 2007 | 05:12 PM
Franklin2's Avatar
Franklin2
The blue light in the dash working eliminates those components though.
Old Apr 26, 2007 | 05:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Could the dimmer switch be the problem? On the older models, sometimes when the dimmer switch was used for high beams, the headlights would either flicker, or go off and on.
Old Apr 26, 2007 | 09:03 PM
Joms's Avatar
Joms
No one has talked about the relay yet? My first thought would be to look there and maybe even trade it with a different one that you know works...
Old Apr 27, 2007 | 12:22 AM
Franklin2's Avatar
Franklin2
No relay on this model. And the blue light is tee'd right into the highbeam wire coming out of the dimmer switch. He said the blue light was working when the highbeams were not. The only thing I can find between the blue light and the highbeams themselves is that plug and the wiring.
It will be interesting to see what it turns out to be.
Old May 3, 2007 | 11:45 PM
aurgathor's Avatar
aurgathor
Yes indeed And it may take a little while.
I tried it a few days ago -- beam was OK.
Last night I had another nocturnal trip home (7 hours) and the beam was flaky for the first 10 minutes until I hit a pothole -- from that point in, it was rock solid for almost all the way, becoming flaky only at the very end. Of course when I checked it today in broad daylight, everything was fine again.
I'll see if I can take the main connector off and check the contacts there.
I_Am_Ozymandias
Feb 26, 2015 08:50 AM
BombThreat
Nov 12, 2013 09:47 AM
Rattler60
Sep 30, 2010 10:16 PM
hvanegas
Jun 7, 2006 06:10 AM
