I Have A 94 Explorer 4.0 I Am Having Trouble With The Temp Gauge It Is Reading High Sometimes As I Drive But It Is Not Overheating When It Does This Any Ideas What It Is.i Replaced The Coolant Temp Sender And Coolant Switch.i Am Also Having Trouble With The 4wd It Will Work In High But Will Not Work In Low
I suggest replacing the thermostat. It may be getting hot enough for the gauge to go up, and the tstat finally opens and it will then go down. If the tstat sticks shut it will cost you some major $$ if it gets too hot.
Another thing to check is the condition of your cooling system. I had a problem recently where the rubber tranny cooler lines were leaking, and the result was a layer of ATF/bug/leaves/road grime which basically made a thick tar-like coating on the front of the A/C compressor. Needless to say, this dramatically affected the air flow through the A/C compressor and radiator. I replaced the rubber lines, and thoroughly cleaned the A/C compressor. Truck seems to run cooler now.
On the cooling problem, it couldn't hurt to flush and change the coolant, and have the flow checked in the radiator, especially if it's old and the coolant hasn't been changed often enough.
I Replaced The Coolant 2 Months Ago.the Rad Is Old So We Will Go From There.i Am Going To Replace The T Stat Hopefully This Weekend And Check The Transfer Case Motor If The Weather Gets Warmer
I'd start with the Tstat. You don't need to drain the radiator to replace the Tstat. Make sure you get the O-ring gasket with the Tstat. Sometimes you have to buy it seperately.
