94 Explorer Problems
Old Mar 6, 2007 | 06:58 AM
PETE PETERMAN's Avatar
PETE PETERMAN
I Have A 94 Explorer 4.0 I Am Having Trouble With The Temp Gauge It Is Reading High Sometimes As I Drive But It Is Not Overheating When It Does This Any Ideas What It Is.i Replaced The Coolant Temp Sender And Coolant Switch.i Am Also Having Trouble With The 4wd It Will Work In High But Will Not Work In Low
Old Mar 6, 2007 | 08:12 AM
taz1y's Avatar
taz1y
if your 4wd work in high but not low your transfer case might be going or it could be a sensor but check the wireing to the sensor could be lose also
Old Mar 6, 2007 | 10:34 AM
marragtop's Avatar
marragtop
I suggest replacing the thermostat. It may be getting hot enough for the gauge to go up, and the tstat finally opens and it will then go down. If the tstat sticks shut it will cost you some major $$ if it gets too hot.
Old Mar 6, 2007 | 11:46 AM
mikeinri's Avatar
mikeinri
Another thing to check is the condition of your cooling system. I had a problem recently where the rubber tranny cooler lines were leaking, and the result was a layer of ATF/bug/leaves/road grime which basically made a thick tar-like coating on the front of the A/C compressor. Needless to say, this dramatically affected the air flow through the A/C compressor and radiator. I replaced the rubber lines, and thoroughly cleaned the A/C compressor. Truck seems to run cooler now.
Also check your fan clutch.
Mike
Old Mar 6, 2007 | 01:48 PM
aquanaut20's Avatar
aquanaut20
Originally Posted by PETE PETERMAN
I Have A 94 Explorer 4.0 I Am Having Trouble With The 4wd It Will Work In High But Will Not Work In Low
your shift motor on the T/C is not working, there is a sticky on this problem
Old Mar 6, 2007 | 07:41 PM
mikeinri's Avatar
mikeinri
On the cooling problem, it couldn't hurt to flush and change the coolant, and have the flow checked in the radiator, especially if it's old and the coolant hasn't been changed often enough.
Mike
Old Mar 7, 2007 | 06:57 AM
PETE PETERMAN
I Replaced The Coolant 2 Months Ago.the Rad Is Old So We Will Go From There.i Am Going To Replace The T Stat Hopefully This Weekend And Check The Transfer Case Motor If The Weather Gets Warmer
Old Mar 7, 2007 | 07:27 AM
marragtop's Avatar
marragtop
I'd start with the Tstat. You don't need to drain the radiator to replace the Tstat. Make sure you get the O-ring gasket with the Tstat. Sometimes you have to buy it seperately.
Old Mar 7, 2007 | 09:29 AM
mikeinri's Avatar
mikeinri
Agreed, start with the cheap/free stuff.
Inspect/clean a/c compressor, radiator, etc. (free)
Inspect clutch fan (free)
Replace t-stat (very cheap)
Get a flow test done on the radiator (cheaper than replacing outright)
Mike
Old Mar 8, 2007 | 06:58 AM
PETE PETERMAN
I Bought The Stat I Just Have To Wait Until I Get Some Warm Weather And Put It In
Old Mar 9, 2007 | 12:40 AM
kslhol's Avatar
kslhol
Where is the sticky on this problem? I can't find it...
Old Mar 9, 2007 | 01:08 AM
aquanaut20's Avatar
aquanaut20
https://www.ford-trucks.com/lc/lc.ph...ansferCase.doc
