86 Ranger 2.9 with Oxygen sensor problems
Old Mar 5, 2007 | 03:24 PM
Triple_E_Farms's Avatar
Triple_E_Farms
A friend of mine has a 86 ranger 4x4 with the 2.9 engine.
He has been having trouble with it loading up.
He said he found an Oxygen sensor but nothing to hook it up to.
He said it was inplace but no wires to connect to it.
Just wondering if all of them were like that or did some one change something on his.
Old Mar 5, 2007 | 04:30 PM
fyre82's Avatar
fyre82
If the truck has EFI, there should be a 3 or 4 wire connector coming out of the loom near where the TFI module connects. It may have gotten melted by the exhaust manifold.
It may be prudent to open up those looms that go to the rear on the right side of your engine to see if thats what happened.
Loading up is one symptom of a bad or disconnected O2 sensor. Pulling codes may help, but if it's not connected there should be some wire stubs or something near.
Good luck
Old Mar 5, 2007 | 04:32 PM
Peter94's Avatar
Peter94
It may also be a 1 wire harness on that old of a vehicle. Check out your fuel pressure regulator by pulling off the vacuum line and looking for gas.
Old Mar 5, 2007 | 05:17 PM
BSmitty's Avatar
BSmitty
The O2 sensor on a 2.9l should have a 3-wire plug. There absolutely should be something connected to it, so search for burnt off wires, or a blank plug.
Old Mar 5, 2007 | 09:25 PM
fyre82's Avatar
fyre82
Thanks Smitty, my truck wasn't at work with me and I was going off of a CRS memory. BTW, Sweet 2x!
There should be a ground wire to right head back in there too.
Old Mar 5, 2007 | 09:28 PM
Triple_E_Farms
He called his self looking in the wire loom for some extra but found nothing.
He never really had much trouble until his computer went south and he bought a new one. It has just gotten worse with time.
Old Mar 7, 2007 | 10:10 PM
Ken00's Avatar
Ken00
My 89 had o/bk, dg/p & bk/lg wires going to it. They ran in a bad place behind the engine, was easy to get caught between the engine and tranny if you were putting them back in the truck. Sorry I don't recall where they originated.
TTDCSB40
Old Mar 8, 2007 | 04:53 PM
Triple_E_Farms
I talked to my friend today and he got to digging around on top of the tranny under some mud and found the connecter.
He said it really helped it start better.
Thanks for all the help, maybe I can return the favor someday.
jdell74
Feb 4, 2016 04:38 PM
EscapesMe
Escape & Escape Hybrid
Oct 16, 2014 07:07 AM
Old93junk
Apr 22, 2012 09:45 AM
churioz
Mar 8, 2012 03:09 PM
ira551
Bronco II
Mar 18, 2006 08:48 AM
