will 292 mount up to 3speed trans 56 f100
The 292 will bolt into a 56 with stock parts. You'll need the bellhousing from the donor truck. You'll need the front motor mount from a 56. The transmission ought to bolt up if it's the narrow pattern transmission. Posting numbers from the transmissions will help answer questions. Does your truck have a 6 cyl?
my 56 f100 was a 6 cyl truck. but when i bought it someone had installed a 272 y block in it. I was going to just rebuild it and reinstall the 272 in it but the local machine shop that is going to do to the machine work said that 292 are better to use than the 272. the 292 is out of a 61 ford f150. the bell house that is on the 272 has # taam7505a on it i cant see a number on the transmission but it a column shift 3 speed that is in my truck. my main question is is the 272 and the 292 have the same block were the bell house mounts
Originally Posted by bbslamjam
one head is from a 312 the other is orignal i was told that was not a problem. if i have the 272 bored to 292 heads is that better
The 272 can be bored out to 292. The later 292 block is supposed to have thicker main webs, and they fixed the length of the main cap bolts to make them longer. It's a toss-up as to which to use.
Be sure to zero-deck your block to make your engine run well. Mummert sells full height pistons to help with this. Mummert also has better head gaskets that help with clamping force on the deck.
Have you found John Mummert's web site yet? Lots of information there.
jaggermk
11-06-2014 08:01 PM
WALFORD'S 56
10-05-2009 11:26 AM
Rellim51
08-20-2008 04:37 PM
scott292y
09-07-2005 05:33 PM
55rodder
13
12-11-2003 07:07 PM
