292 to 390 swap
292 to 390 swap
Hey everyone. I have a '64 f-100 with the 292 and 3 speed manual tranny. What would i need to convert the truck to a 390 engine. Will the trans bolt up to the bellhousing or is there a special adapter for that. Really need to know everything on how to do this so my truck wont be sitting in the driveway through winter.
on
1 Post
Well your not going to get a Y block tranny to bolt up to an FE motor..... I dont remember if TransDapt makes a adapter plate for that conversion or not...But I dont think with the Torque that the 390 has the Little 3 speed that was behind the 292 would last long anyway..
I think like Gtex said..I would just do a motor and trans swap!!
Russ
Russ
Here are a few thoughts.. If you decide to swap in the FE, you should look for an engine swap frame kit. The 292 bolted in at the timing cover and the flanges on the bellhousing. You would need to find an timing cover and bellhousing off of a FE powered 65-67 4x4 truck to pull the correct "factory" swap parts.
--Mike
--Mike
--Mike
--Mike
I've heard that the front crossmember from an FE equipped '65 f-100 would probably work but i'm still not sure how to do the tranny setup. I can't find any pictures or specs for my 3 speed and the newer one from the '65 and '66s. Think you guys are right about my tranny being too small for a 390. Guess i'll be looking at changing the whole driveline along with the motor unless I find an adapter. Where's a good place to look for specs on these things??
there are aftermarket crossmembers for the side mounts on FE's, I made my own from a crossmembr out of a early 60's passenger car, I have an adapter for the FE bell housing that has the ears for the that crossmember, but its for a 4spd truck trans, don't know if one was made for a 3 speed
Chad63F250
05-04-2016 12:09 AM
blisstruck
50
04-19-2015 08:51 PM
slckkw
11-14-2010 09:24 PM
46yblock
06-14-2005 08:10 PM
blubyu74
10-23-2003 07:10 PM
