Burnt CD's
Old Nov 11, 2006 | 02:05 AM
Da Wookie's Avatar
Da Wookie
Burnt CD's
Some CD's that I've burnt don't work so well in the player. Anyone have success with a particular CD brand???
Old Nov 11, 2006 | 03:03 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
memorex is a pretty good brand
Old Nov 11, 2006 | 06:20 AM
wildcard30's Avatar
wildcard30
I've had good luck with all brands...
Everything from the no name brands like office depot to the "high end" HP discs.
Old Nov 11, 2006 | 07:56 AM
grant5127's Avatar
grant5127
I've tried several brands, but it's a hit and miss deal.... the player states "bad disc" sometimes reinstall and it plays... WTF? all disc seem to be ok in the wifes escape tho..
Old Nov 11, 2006 | 08:04 AM
AzBlueWolf's Avatar
AzBlueWolf
try a different program to burn the cd's or burn them at a slower speed
you might also try using a cd head cleaner ( a special disk with a little brush on it and some cleaning solution) usually available at any store selling electronics
Old Nov 11, 2006 | 08:12 AM
osbornk's Avatar
osbornk
I've used all brands and they have worked without fail in my F-150 (it has the CD player and the tape player), my wife's Escape and my Towncar with a Panasonic 6 disc changer. Brands don't seem to make any difference. Maybe it's the burner or it needs cleaning.
Old Nov 11, 2006 | 08:44 AM
spiggy769's Avatar
spiggy769
I myself have used Nero and I Tunes with absolutely no problems whatsover.
Old Nov 11, 2006 | 09:29 AM
TXFX4's Avatar
TXFX4
I have used all diff. types and brands and no prob. try burning at different speeds or different program like azbluewolf said.
Old Nov 11, 2006 | 11:23 AM
fordtruckman's Avatar
fordtruckman
use nero that what i use and have never had a problem, also like with my radio it wont play MP3's so if yours doesnt say MP3 on the front then make sure you burn the cd in WAV. format
Old Nov 11, 2006 | 12:29 PM
osbornk's Avatar
osbornk
I've used both Nero and Roxio with no problems with either.
Old Nov 11, 2006 | 02:38 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
good point, I had forgotten that some of the cd players are CD only, not MP3/CD...make sure to specify in your options to burn as an AUDIO cd if you don't have the MP3 player
Old Nov 12, 2006 | 10:12 AM
sgt82nd's Avatar
sgt82nd
Burn speed is almost always the issue - burn your CD/MP3's slowest speed if you have problems.
Shawn1024
2004 - 2008 F150
17
Feb 3, 2006 11:42 PM
brainchild
Jul 11, 2005 06:38 AM
Iceman8984
Oct 29, 2003 08:41 AM
kwik69
Aug 1, 2003 01:38 PM
