Engine won't start, fuel in oil pan
Old Apr 30, 2006 | 10:11 AM
hunter1897's Avatar
hunter1897
I have a 302 that has run fairly well the last few years, then all of a sudden I can't start it this year. Been putting in a Duraspark EI over the last few weeks with no success. Dropped the oil pump rod into the pan, and noticed my oil pump is loose down there, so I pulled the oil pan drain plug to empty the pan thinking I'd fix the oil pump and try it all over again, when the oil came spewing out, loaded with gas.
Question is, does this mean all that fuel is just blowing by my rings and right into the pan? I certainly have been cranking the engine a lot the last few weeks trying to get it to start. Yesterday it sputtered every 5-10 seconds, but no real ignition.
Old May 1, 2006 | 10:15 AM
Kemicalburns's Avatar
Kemicalburns
fuel in the oil is not good. your fuel pressure regulator is probably bad or your injectors are stuck open. I would start with the fpr, replace the oil and filter. run for a day or two then replace the oil again. the gas more then likely washed the bearings which is very bad so the whole bottem end needs to relub itself. thats why it wont start
Old May 1, 2006 | 10:20 AM
j&bsuv's Avatar
j&bsuv
fuel pump if its on the block. diaphram broke/leaking
Old May 1, 2006 | 11:37 AM
Kemicalburns
good call J&B, i didnt notice what year he was talking about. i assumed efi
Old May 1, 2006 | 05:33 PM
hunter1897's Avatar
hunter1897
Okay, thanks. Yeah, mechanical fuel pump on a 1971 302, carburated. I can hit the trottle and get fuel pumping into the carb. I have a see-through in-line fuel filter near the carb and fuel is getting up to the carb...took the top off the other day and the bowl is filled and the float is working. Could it still be a bad fuel pump diaphragm? I guess it's good that you didn't mention a totally shot rotating assembly (rings, etc.).
I think I'll put a negative battery cable on too...just don't think I'm getting the spark I need and it's probably 30+ years old.
Old May 2, 2006 | 06:40 AM
cujo8's Avatar
cujo8
To test your rings do a dry and wet compression test, if your rings are bad you will have poor compression values.
Old May 2, 2006 | 09:18 AM
uncle junk's Avatar
uncle junk
i had a intake that was cast and crackded on me direcctly under the carb and i was getting fuel in the oil just a thought for you .it probably isint your problem cause i have really never seen another intake crack on the inside
UncleTom
Oct 7, 2016 08:38 PM
6.9 BLUES
Apr 2, 2014 12:21 AM
moneypit79
Jul 8, 2013 08:27 PM
Raymond
18
Dec 8, 2011 07:59 PM
Oscar Meier
Sep 25, 2003 10:01 PM
