1954 F250 Frame
Old Feb 9, 2006 | 08:29 AM
amg26zephyr's Avatar
amg26zephyr
4wd Low
1954 F250 Frame
Hi Everyone. I'm new to the forum, and have started a frame-off restoration of a 1954 F250 Flatbed. Does anyone know where I can find a rear frame crossmember (original shape).
Old Feb 9, 2006 | 08:58 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 9, 2006 | 12:40 PM
FOWL1's Avatar
FOWL1
I have a '53 and '55 F-250 pick up and the only place I know is to either have it custome made by someone like Dan Carpenter or to buy a used one. You could try Bruce Horkey Wood and Parts as he has some used trucks and might seel the parts. Also there is a guy in North Carolina "Flashback F-100's" that might have something used. I had the same problem finding bed parts for mine and ened up buying the '53 to use the parts for the '55. The F-250 is a little harder to find some parts for. I saw a guy at the Pidgeon Forge Ford Truck Nationals that had a '55 F-350 with a 9 foot bed. He had his sides made by Dan Carpenter. Good luck
Old Feb 9, 2006 | 01:38 PM
1954F250's Avatar
1954F250
I don't know about frame parts, but I have found mechanical parts for my 1954 F-250 at joblot auto.
I am having trouble finding the 12" x 2" brake drums. Does anyone know of a source for these?
Kevin
Old Feb 9, 2006 | 02:03 PM
AXracer's Avatar
AXracer
AFAIK all the crossmembers should be the same on the 100's 250s and 350s. Unless the flatbed used a different rear crossmember, don't limit your search to just one from a 250.
Old Feb 9, 2006 | 02:33 PM
Fomoko1's Avatar
Fomoko1
Welcome to FTE amg26zephyr. It will help to find parts quicker if you fill out your location so it shows up automatically in every post without having to go into your profile.
Old Feb 10, 2006 | 05:47 AM
FOWL1's Avatar
FOWL1
Actually the F-250 bed is wider and taller, at least the pick up bed is, than the F-100. Hence the problem. If you have or are making a flat bed, wouldn't you be able to use wood for the cross members. I would think that would be acceptable, unless you are using the truck for hauling heavy duty stuff. I know the pickup bed is taller and wider than the F-100 because there are small wheel tubs in the F-250 bed and the tail gate and front panel are taller. The did make some 8 foot F-100 beds, I saw them at the PF Nats, but I'm not sure if they are the same bed as the F-250. Steel tube might also work for a bed cross member.
Old Feb 10, 2006 | 07:29 AM
AXracer's Avatar
AXracer
Unless I'm misreading something he is looking for a frame crossmember not a bed crossmember.The frames were all the same.
Old Feb 10, 2006 | 07:47 AM
FOWL1's Avatar
FOWL1
oops. I'm the one that didn't read it right. Sorry.
Old Feb 10, 2006 | 10:09 AM
amg26zephyr
4wd Low
The frame crossmember is what I need. It should be easier to search for an original off an F100. Thanks for the info. By the way, I am located in CT if anyone has one.
--Adam
Old Feb 10, 2006 | 11:15 AM
AXracer's Avatar
AXracer
all the frame from F100-350 in 53-56 (and possibly 57-59) were identical as far as crossmembers are concerned, so it shouldn't be a very difficult search. It is quite possible someone on here has one or a dozen sitting around.
