Welding boxing Plates
Old Feb 9, 2006 | 01:11 PM
F100man's Avatar
F100man
I am getting ready to weld boxing plates in on the rear frame rails and have to answer a few questions first. I was going to have the frame powder coated but have changed my mind. I am now going to use Chassis Black instead. First question is do I coat the area first? Second I was going to cut symetrical circles in the plates to allow acess behind the plates. What do you think of this idea? I am going to bolt the rear cross member in and weld the boxing plates around the crossmember for a cleaner look. Or should I just epoxy prime and paint the frame? Any suggestions would help----Thanks
Old Feb 9, 2006 | 02:13 PM
AXracer's Avatar
AXracer
You won't be able to paint the frame with any paint besides "weld thru primer" and then weld the plates in without setting the paint on fire. I highly recommend cutting ~3x6 oval holes in the boxing plates for access and finishing the inside of the frame. That size hole will allow you to swing a wrench inside the frame. Round holes will look good, but you won't be able to do much wrenching thru them. I'd suggest doing a search here, frame boxing has been discussed in some depth in several topics lately, and it will save retyping and forgetting something important.
I might suggest taking a minute to reset your font to a smaller size.
Old Feb 10, 2006 | 07:59 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I was just going to suggest that we all set our fonts to his size! I can read it much more easily....
Vern
Old Feb 10, 2006 | 08:31 AM
AXracer's Avatar
AXracer
Vern
You mean everyone else doesn't have a 21" monitor????
Vern, go into the view menu on your browser menu bar, click on text size, choose larger or largest. (or trade up that 14" monitor!)
Old Feb 10, 2006 | 12:47 PM
GreatNorthWoods
Mine's so old it's probably a 10 incher....
Vern
Rokcrln
59
Feb 25, 2017 05:50 PM
Gary E
25
Nov 9, 2015 10:28 PM
highboy1975
Offroad & 4x4
Jan 8, 2009 12:41 AM
bearsman_herm
Mar 30, 2004 12:30 AM
1988 Ford 150 4x4
Jan 5, 2003 12:25 AM
