wheel size
Old Nov 15, 2005 | 11:17 AM
77mudder's Avatar
77mudder
wheel size
i want to get 16" wheels for my 77 f250 4x4. will i have to do anything to the brake drum or will it clear it no problem? i plan in 35/14.5/16 boggers(no lift)will that work also?
Old Nov 15, 2005 | 11:23 AM
74 F100 351m's Avatar
74 F100 351m
16 inch wheels will fit. as for the 35's it dependes on if you have a high boy or not. Does it have a 390 or a 400? The one with the 390 might be a high boy. The one with the 400 is not.
77mudder's Avatar
77mudder
it has a 351m.
Old Nov 15, 2005 | 11:51 AM
74 F100 351m
I think 33's will be tight. My 78 F250 4x4 had 30's on it a little fex and they got close to the fenders.
Old Nov 15, 2005 | 11:58 AM
77mudder's Avatar
77mudder
it has 33's on now and they are fine. I still have some room but they are on 16.5's
Old Nov 15, 2005 | 07:25 PM
74 F100 351m
Mine was a farm truck with a hayspere on it so the spings mightbe week. And I didn't think that the rim size didn't change the outside diamater.
Old Nov 15, 2005 | 07:33 PM
fordraceboy's Avatar
fordraceboy
boggers are a WIDE tire!! those 14.5's are gonna be closer to 15 on a 10 inch wheel.. the 77-79 are cosidered lowboys.. you can run a add aleaf in the front and rear for an easy 2-2.5 inches of lift for low buck, 70-80 bucks a piece for a pair of add aleafs... put those on a 78 and fit 35x12.5 on 16's with no problems...
Old Nov 15, 2005 | 08:38 PM
bremon140's Avatar
bremon140
Try 12-15 rims. I've got 15-38-15's on 14-15 rims and 6" lift system on my '79 Bronco and they balloned out for plenty of clearance...nice roostertails!
Old Nov 15, 2005 | 08:41 PM
fordraceboy
6 inches of lift does wonder for clearance though...
Old Nov 15, 2005 | 08:43 PM
bremon140's Avatar
bremon140
no doudt...inches count
Old Nov 15, 2005 | 08:53 PM
plowpusher's Avatar
plowpusher
16 was an optional wheel on your truck the'll fit no problem. Just a note to those of you who don't know. Early 77 f250 4x4 with the "divorced" transfercase is the highboy (3 driveshafts) the later 77's or 77 1/2 f250 4x4 have the "married" tranfercase like the 78-79. 36.5 fit the highboy with no lift but will rub the steering on hard right turns if you have a late 77 you will have to lift it
