mustang 2 clip
Hi Brian, Welcome to FTE The best truck show on the net!
I read your bio, and I suppose you are looking to work on the 61. AFAIK, the Pinto & Mustang front ends are different. The Mustang front end is much lighter weight (The Pinto even lighter) and is not found on any Ford trucks.
Ther are members here that have done that and will be along shortly to help you out.
John
John
While a popular choice for Street Rodders at one time, the M-II front suspension isn't that spectacular. It's really too light for use in a truck, IMO. I would look towards the Aerostar clip if I were you. They are more plentiful, built heavier, have better brakes, better suspension geometry, etc.
Pintos are the same but different, are lighter duty as noted and should not be used on something as heavy as these trucks.
Do you plan on showing your 61 or just a work horse? that will determine what to do with the front. the MII will allow you to bag it and still give all the benefits of disc brakes and better suspension. I was'nt going to bag mine (64 f100 long bed) but I did want to lower it, so I went with a Volare front but the ones listed on previous posts are just as good. plan ahead and you'll do alright good luck.
Robert (gangstakr)
Robert (gangstakr)
