Door Ajar Light won't go out
should I attempt to fix the problem myself?) or should I take it to a dealer to fix? I have a haynes manual(I haven't looked in it yet to see about replacing the sensor) Am I thinking in the right direction, or could it be something totally different?Thank you in advance for any replies.......
Steve Piper
It won't last forever, but neither will replacing the latch, which costs a lot more.
I am a new member here but not a stranger to turning wrenches, or "bending" them from my days as as a technition in ithe Army.
The man in green speaks the truth, a shot of the miricle worker may do it. Think of how many times that area has been lubricated since you bought the vehicle or it was manufactured. Unless I am wrong, and the PTB "Powers that Be" can correct me later, the switch is pressure activated, IE the latch rotates up to release the jamb or anchor and then activates the switch. The dust boot on the switch may have failed and collected dirt around the plunger and stuck. A shot of that around the latch area may relase it and lube it to allow it to function again.
However (Pardon the newbie to add aditional info) you may have to tear into the mechanisim if this doesn't do it. Follow the manual Haynes or otherwise to the letter. You don't want to mess up any seals or electrical circuts trobleshooting the problem. Primarily(sp) now it's electrical and possibly mechanical (Meaning you didn't add if you had problems opening the door prior or door strikes as well as immertion problems or adding to it by making it a mechanical problem while tearing in to it). Follow the manual and remove the switch or at least access it to inspect and lubricate for your first try. Then check the latch and mechanism operating measurements, or how they are supposed to work. I have seen many switches operated by bell crank, striker or springs come up as an electrical failure and it was due to a machanical cause. Take a look and report back.
Good Luck!
(Please Pardon the New guy;-))
YES,YES,YES!!! The WD40 spray worked for my Sable. The dome light stayed on, and the door ajar light was glowing on the dash. Sprayed all 4 doors with WD40 as outlined below, and within 10 minutes the problem vanished. It's been well over a year without a problem.
"This procedure is a solution to the dome lights not shutting off when the car’s doors are closed. I know for sure that this will work on any vehicle that has the dome light switch as an integral part of the door latch.
If your dome light does not shut off when you close the door, simply use a can of WD40, with the thin nozzle attached. Insert the thin nozzle into the lock cylinder and spray generously, then insert the nozzle into the latch mechanism and spray.
Our Taurus, a 1997 GL, has had this problem since we bought it in 1999, and I spray the lock and latch every time I change the oil, as a preventative measure. It works great, as the only permanent solution is to replace the latch mechanism."
Check out & "mine" the "Read First", "Technical" sticky Ken has located atop this forums main page, it has links in it for answers to many of our common Ranger problems, including the one your having. https://www.ford-trucks.com/forums/s...d.php?t=107538
So if the above urgings to try WD-40 doesn't convince you, read through the link provided in the technical forum.
Just scroll down to the "miscellaneous" section at the bottom & click on the "dome light, door ajar" link.
Enjoy all the other info links posted &, HAPPY MINING there!!!!!
Let us know how it goes.
Steve
