leaking axle tube
Old Oct 16, 2005 | 07:48 PM
powerstroke6ltr's Avatar
powerstroke6ltr
leaking axle tube
Hi. I was under the ranger today and noticed that the little rubber tubing coming from the driver's side of the rear axle is leaking...or spraying for that matter. There is oil spray residue on various parts under my truck...what is the tube for anyways and where does it clip to? I just used the clip and stuck it to the frame rail....
Old Oct 17, 2005 | 07:54 AM
Bart99GT's Avatar
Bart99GT
Its a vent tube for the differential. Usually if fluid starts spraying out of the vent, it is probably partially restricted somewhere. Pressure builds up in the housing until it is sufficient to overcome the restriction in the vent and then it sprays oil all over the place. If you can get it loose from the axle you can try cleaning it out or just replacing it outright. I would also suggest checking the fluid level in the differential at the same time.
Big Sky
Jun 24, 2011 08:39 PM
yellowtonka2
Sep 30, 2009 08:35 PM
sean23johnson
Mar 15, 2007 01:15 PM
blackjack390
1997 - 2003 F150
Jan 16, 2005 11:53 AM
dangrimsley
1997 - 2003 F150
Nov 23, 2003 04:31 PM
