i was under my truck yesterday installing another starter and i noticed the right (pass) side axle tube is leaking?? i know the seal is inside the axle tube, but to get to the seal do i have to pull the carrier out?? if i do this might be a good time to install lockers and 4.10's or 4.30's!
I just finished installing an outboard seal on mine. I had to hone out the outer end of the axle tube a bit with a ball hone, but I finally got it to fit. I found the number somewhere on this forum, thanks to whoever posted it.
It is a 16146 seal, The Carquest number is 4762N, and it is 1.618 x 2.841 x .500
I was able to install the factory dust seal on the outer end of the axle shaft as normal. Time will tell how it works. I figure, it will cut my leak down to a minor annoyance at worst.
I put a new dust seal on the axle shaft as normal. The dust seal rides on the face of the axle tube, so it does not interfere with the new seal I installed inside of the axle tube. I have some pics, pm me if you want them.
noticed my pass side is leaking too...i was afraid it would be like my jeep, gota pull the whole damn front axle apart short of the pinion to replace the things guess ill check wheel bearings an ball joints while im at it...oh fun
