1983 302; turbo or supercharger
Old 07-28-2005, 06:55 PM
Dunkindonuts97's Avatar
Dunkindonuts97
Dunkindonuts97 is offline
Exclamation 1983 302; turbo or supercharger
Do they make turbo or superchargers for '83 302 engine? I have been looking and all I can find is 66-71 and 86-up. If you know of any or of any modifications I could try to fit one for a different year on then that would be very helpful.
Thanks
Old 07-28-2005, 08:33 PM
stevef100s's Avatar
stevef100s
stevef100s is offline
An SC or turbo can be used on ANY year 302. Just not a STOCK 302. Forced induction requires that mods be made to an engine. Cast pistons won't live very long under boost. A special camshaft, as well as adjusted clearances inside the engine would be other mods needed for optimum power gains. Plenty of info on the net.
Old 07-29-2005, 08:53 PM
fastback69's Avatar
fastback69
fastback69 is offline
Old 07-31-2005, 08:06 PM
F150daniel's Avatar
F150daniel
F150daniel is offline
Theres more than a few guys running turbos on STOCK 5.0s, some making 400+hp.
Old 08-01-2005, 05:36 AM
stevef100s's Avatar
stevef100s
Most of these are with a stock 5.0 GT block. These come stock with forged pistons. 400 hp isn't much to brag about. I can get that with a change of heads, rocker arms, and headers on a stock GT 5.0 engine. To really take advantage of boost, a stock engine just won't do. There are turbo 302 engines putting out WELL over 1000 horsepower, though not with a stock block (for long).
Old 08-01-2005, 06:32 PM
F150daniel's Avatar
F150daniel
I mean stock 5.0 with stock TB, stock intake, and stock heads.
Lots of boost on a stock 5.0 is not the best way to make power but, it can and has been done.
And heres a nice little 1177hp at 5800rpm carbed 302 that drove home from the dyno.
http://www.turbomustangs.com/forums/...threadid=37521
Old 08-07-2005, 12:37 PM
Jimbo302's Avatar
Jimbo302
Jimbo302 is offline
Not all of them, and besides the blocks come apart if you hang around 500rw for too long.
Um, no you can't.
Old 08-07-2005, 11:43 PM
stevef100s's Avatar
stevef100s
[QUOTE]Originally Posted by stevef100s
Um, no you can't.[/QUOTE
If I say it it's true. http://www.carcraft.com/techarticles/116_0307_ford/
And yes, all 5.0 GT engines do have forged pistons.
Old 08-08-2005, 12:48 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
I read that article and noticed something.....a set of 1.7RR's will help to increase the lift, but how in the world will they increase duration if the profile of the cam is not altered?
Old 08-08-2005, 10:12 AM
stevef100s's Avatar
stevef100s
What makes you think that the duration needs to be increased to make those numbers? The extra lift caused by the increased rocker ratio opens the valves further, thus allowing more air to pass in and out of the cylinders.
Old 08-17-2005, 09:52 PM
cjjeeper85's Avatar
cjjeeper85
cjjeeper85 is offline
[QUOTE=stevef100s]
Only to 92 then in 93 they changed to hypereutectic pistons.
Old 08-18-2005, 08:55 PM
91GT turbo's Avatar
91GT turbo
91GT turbo is offline
[QUOTE=stevef100s]
If you believe everything you read on the net, nevermind.
Old 08-18-2005, 09:09 PM
stevef100s's Avatar
stevef100s
I've also seen those power numbers on the dyno. AFR heads kick butt.
dillon.proctor173
03-06-2011 06:04 PM
Big_Dom
13
04-22-2010 10:15 AM
silly34
05-22-2009 09:33 PM
kilbrethj
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-04-2007 07:10 PM
Pete B
01-20-2006 07:44 PM
Quick Reply: 1983 302; turbo or supercharger
